How to Calculate Boat Angle for Straight River Crossing?
  • Thread starter Thread starter kboykb
    Boat River
To calculate the angle for a boat crossing a river with a current, the boat's speed in still water is 11.0 km/h, and the river's current is 3.0 km/h. The correct approach involves using vector components to determine the angle needed to maintain a straight path across the river. The tangent function is relevant, specifically the arc-tangent of the ratio of the river's speed to the boat's speed (3/11). Additionally, applying the Pythagorean theorem helps find the resultant speed relative to the shore. Understanding these concepts is crucial for solving the problem accurately.
kboykb
A: A boat capable of making 11.0 km/h in still water is used to cross a river flowing at speed of 3.0 km/h. At what angle (in o) must the boat be directed (from the perpendicular to the shore) so that its motion will be straight across the river?
B: What is the resultant speed relative to the shore?
I'm not sure of the Exact Equations.. Possibly
Ax = A*cos(Theta) Ay = A*sin(Theta)
Bx = B*cos(Theta) By = B*sin(Theta)
Ax+Bx=Cx .. or Ax-Bx=Cx
(I'm at work right now, I forgot the last equation .. Ay/Ax = The tangent of Theta ? By/Bx)
For my solution I drew a vector triangle. One directly North, one at the head of this vector going to the right (east) .. and then a resultant line connecting these two vectors. Mainly I just divided 11/3 and took the tangent of this, but couldn't find the correct answer. I can't really attempt the 2nd problem without the way to do the first.
Thanks in advance for the help :)
The vector of length 11 is the hypotenuse of the right triangle so you don't want the tangent(11/3). The tangent(3/11) would be closer but that is still wrong.
Draw a picture roughly to scale so you have an idea of the correct answer.
That should be arc-tangent(3/11) above, hope that was obvious.
Okay, that does give me a better visual of everything. I have something that looks like this (Ignore the Text)
with 11 as the hypotenuse. If the top vector is 3, would the straight North line be 10.8? (By the pythagorean theorem)
I'm not sure what formulas to use here. I'm pretty sure I need to break it down into x and y components though
