How to Calculate Bond Strength in a Molecule?
The discussion revolves around calculating the bond strength in a carbon monoxide molecule, given its reduced mass and the wavelength of absorbed infrared radiation. The context involves vibrational transitions and the relationship between molecular properties and absorbed energy.
  • The original poster attempts to calculate the bond strength using the reduced mass and wavelength but expresses uncertainty about the appropriate equations. They question the meaning of the force constant (k) and its relation to bond strength.
  • Some participants clarify the definition of k and suggest that it characterizes the bond's stiffness, while others inquire if k can be equated to bond strength.
Participants are exploring different interpretations of the equations involved and discussing the definitions of terms like bond strength and force constant. Guidance has been offered regarding the calculation of k, but no consensus has been reached on the relationship between k and bond strength.
The original poster notes that the reduced mass is provided in the problem statement, indicating a potential constraint in their approach. There is also a mention of the need to clarify the definitions and relationships between the variables involved in the calculations.
solas99
Carbon monoxide molecule, which has a reduced mass of 6.85 amu, absorbs infrared radiation wavelength of 4.6um. if the absorption is due to vibrational transitions, calculate the strength of the bond in molecule
u=(m1*m2)/(m1+m2)
1. (12*16)/(12+16)=6.85 amu= 1.13e-26 Kg
here i calculate the reduced mass...but the reduced mass is given in the question! i just don't know what equation to use to calculate bond strength from wavelength and reduced mass..
there is another equation for frequency of vibrations: v=1/2pi \sqrt{k/u}
but i don't know what k stands for? and how we calculate it
is there any other equation I am missing?
thank you!
k is called the force constant of stretching the bond between carbon and oxygen, and it characterises the stiffness of this bond. Search your notes what was called "the strength of the bond". You can calculate k from the given data. Remember that a vibrating molecule absorbs that radiation which frequency corresponds its vibrational frequency. ehild
E=h(n+1/2)w
is k the bond strength?
from equation λ=2pic\sqrt{u/k}
do we then solve for K, to give the bond strength?
thanks a mill :)
Well, k is not the bond strength, but your book might call it so. Anyway, calculate it.
ehild
12K
