How to Calculate the Length of a Capillary Tube for a Drip-Irrigation Emitter
The problem involves calculating the required length of a capillary tube for a drip-irrigation emitter, given specific parameters such as water pressure and desired dripping rate. The subject area relates to fluid mechanics and the principles governing flow through narrow tubes.
  • Exploratory, Conceptual clarification
  • The original poster attempts to convert units and set up the problem but expresses uncertainty about how to relate the cylinder dimensions to the given pressure. Some participants inquire about the relevance of the Hagen-Poiseuille equation in this context.
The discussion is ongoing, with participants exploring foundational concepts in fluid mechanics. Guidance has been offered regarding the potential need for specific equations, but no consensus has been reached on the approach to take.
The original poster mentions a lack of familiarity with the Hagen-Poiseuille equation, which may be a critical component for solving the problem. There is also a reference to the constraints of their current learning focus in Soil Physics.
maxnormal
A drip-irrigation emitter constructed of a coiled capillary tube is inserted into the wall of a drip irrigation line with a constant water pressure of 5 psi. Compute the required length of the emitter’s capillary tube to produce an emitter dripping rate of 2 litres per hour if the capillary tube diameter is 1mm.
Pressure = Force * Area
Volume of Cylinder = ∏ * Length *Radius^2
I converted all the units into SI. I know I need to solve for length of the cylinder, but when I try to equal the cylinder dimensions to 5psi nothing works out. Just don't know how to approach the problem yet. Any help would be appreciated. Thanks.
5 pounds/inch^2 = 34,473.7865 kg/ms^2
2Litres/hour = 5.55x10^-7 m^3/s
diameter = 1mm = 0.001m
radius = 0.001m/2 = 0.0005m
Hi Maxnormal. Welcome to Physics Forums!
Are you learning fluid mechanics? Have you learned about the Hagen -Poiseuille viscous flow equation?
Chet
Chet
Hey! Right now I am learning Soil Physics. And I have not learned of that equation yet. Will I need that equation to solve the problem?
Google it and see if it satisfies your needs.
Chet
14K
