I How to calculate the mass of gas in a tank?
  • I
  • Thread starter Thread starter Leopold89
    Gas Mass Tank
The discussion revolves around calculating the remaining gas mass or particle number in a pressurized air tank, considering factors such as temperature, pressure, and phase changes. The user has time series data for gas pressure and room temperature but lacks direct temperature measurements of the gas. They explore the complexities of transitioning between liquid and gas phases and the impact of thermal inertia and heat transfer on their calculations. The conversation includes various thermodynamic equations and models to estimate the gas mass, emphasizing the need for accurate initial conditions and the use of steam tables for properties of substances. Ultimately, the user seeks clarification on integrating thermodynamic principles and the correct application of equations to derive the desired results.
  • #51
Juanda said:
But that's only enough if we knew the content is 100% gas because it'd occupy the full volume or 100% liquid as long as it is at 100% capacity.
Another variable in the equations I presented was the mass fraction vapor, which is an intensive property. See the equations I derived in my analysis.
Juanda said:
That's probably it. I'm a little rusty on this but, from what I remember, power cycles involving vapor always have that constant behavior inside the bell.
No way. The temperature and mass fraction vapor are sufficient to fully establish conditions within the bell.
Juanda said:
I checked THE book (Çengel) again and the constant pressure is mentioned. I assumed the constant pressure (and temperature) was a result of the phase change but the phase change is actually not even mentioned. So it is imposing a constant pressure inside the bell that is causing the constant temperature during that part of the process.
There is a big difference between constant pressure spatially and constant pressure temporally (i.e., during the process). In the Rankine cycle, the boiler is operated at constant pressure because the hydrodynamic pressure drop in the boiler tubes is low, and, in the condenser tubes, the pressure drop of the water vapor and liquid water combination flowing through the tubes is hydrodynamicallly low. These are mechanical constraints of the process equipment rather than thermodynamics.
Juanda said:
I don't know how to describe a phase change where the pressure is not held constant then. I feel I need more information.
Please review the analysis I did in post #11 and get back with me regarding any questions. There are only a few equations presented in that post.
Science news on Phys.org
  • #52
Thank you for your input, I really appreciate that you took so much time out of your day.
Juanda said:
would it be possible just to weigh the loaded and unloaded tank?
In theory at some point in the future one could measure these masses, but not in the short term.
Juanda said:
why isn't it possible to measure the temperature inside?
The main reason is that I don't have the right thermometers for that. Before your comment I did not even know I could do that, but if I could find a suitable thermometer to integrate into the setup, I could also measure the temperature directly.
Juanda said:
could you characterize the valve?
I don't understand. Could you give me an example?
Juanda said:
If the full content of the tank were a gas, the approximation to find the mass isn't too difficult depending on how much accuracy you want.
I have posted a plot of only gas/vapour in post #39, but I can also upload plots in this post as well.
Juanda said:
I'm aware my approach seems different from what you've been doing in the thread.
I don't mind. Even if it should not work, it is a welcomed exercise to get practice in thermodynamics. I just need some time for the implementation.
Juanda said:
By the way, are you sure you have a saturated mixture in the tank? I think you haven't shared what's the chemical inside in detail so I couldn't check with some tables (if there are any for that compound).
Not in all tanks, but in one I believe yes. For most chemicals I did a mistake like for ##\mathrm{CO}_2##, where I followed Wiki, where they said you have liquid carbondioxide above 5.2bar and below 31°C, but after Chestermiller's explanation, I have corrected my mistake.
Juanda said:
Since the temperature keeps dropping slightly, I assume it's discharging but the pressure is not changing.
In my interpretation the dropping temperature is caused by the daytime (evening) and maybe the pressure does not follow, because the atmospheric pressure increased at that time. Btw I could also get a time series of the atmospheric pressure, but from another room, and then correct the gas pressure for the surrounding pressure.
  • #53
Leopold89 said:
(Referencing the different approach I initially took in #44 and #45)
I'm actually now trying to follow what you and Chester did before. As he said, maybe by correcting the points he marked it'd be possible to approximate the system.
Leopold89 said:
(Referencing the characterization of the valve)
You could install valves that measure the volumetric flow. If the density of the vapor is known (should be possible to find it from thermodynamic properties) then you can know the mass output.
Alternatively, if you knew the characteristics of the valve, you could calculate the output flow from the thermodynamic properties.
By the way, did you consider the floater or a similar sensor to find the amount of liquid inside?
Juanda said:
Lastly, @Leopold89 you are interested in knowing the remaining mass in the tank. We have already stated that the problem occurs when there is a mixture of gas and liquid inside because your sensors don't provide enough information by themselves. I tried to propose some engineering solutions that don't involve complicated calculations such as weighing the tank but that might be difficult. How about installing a floater so you can know how much liquid there is inside? For example:
Once the volume of liquid is known, you'd easily find the mass in the tank once the properties of both liquid and gas are known.
  • #54
Yes, but it is not possible.
Maybe I can aquire these from the manufacturer. I think I would need the area of inlet and outlet an then scale the pressure measurement to the outlet area. I just don't understand the "Alternativly", because I would still need to measure ##Q_G##.
  • #55
That's a shame. Calculations it is then. At least in the short run. As you said, if weighing the content is possible in the future it might prove to be the best approach if you can't manage to model the system in a way that provides reliable results that match the real behavior you're observing with your current sensors.
I meant I think you have 3 alternatives regarding the valve.
  1. Measure the flow experimentally.
  2. Characterize the valve and measure the flow indirectly using calculations. Then check the results with your experimentally measured P-T graphs to ensure your results make sense.
  3. Similar to the previous options but without characterizing the valve. You'll have to solve the problem several times assuming different valve characteristics hoping that, for some values for the valve, the results match what your experimental measurements of P-T are reading.
By the way, probably there are books, articles or other webpages covering the characterization of valves in more detail or in more convenient units (those 816 and 962 might be converting factors but I don't really know it).
  • #56
What are the dimensions of your actual tank (schematic sketch?)
  • #57
Volume of the tank is 50 liters, the outer diameter is 229 mm and length is 1655 mm. No sketch available. Why is this important?
I have tried to compute the differential equation by @Juanda in the attached image, but for a pure CO##_2## gas: ##\dot m = \frac{\dot q -c_V \dot T}{c_VT - h_\mathrm{out} -q}m##
It starts out well, but somewhere seems to be an error and the mass jumps around 0. What seems strange to me is that the specific enthalpies and internal energies are below zero. I get those from the Python package pyromat.
Edit: Found the implementation error. The ode should now be computed correctly, but the result is still implausible.
  • #58
Inlet: DIN 477-5 Nr. 57 (W 30 x 2 LH)
Outlet: 1/4 NPT-M
But this is the valve for hydrogen tanks, not 100% sure if others are the same.
  • #59
Outlet: 1/4 NPT-M
That's something but by itself, it's not of much use. You either input the geometry in CFD software or experimentally characterize the valve to determine how the flow is through it depending on the boundary conditions.
I still couldn't invest time on this thread again. It's a hard one and I'd need time to focus on it.
  • #60
You can measure the temperature with thermocouples. They are often mounted thru the tank wall using a thermowell, which is essentially a closed-end threaded tube that attaches thru a threaded hole in the tank and contains the thermocouple.
The other implementation is feed the thermocouple thru the top of the tank using a gland fitting. This has the advantage that you can place the thermo-couple at various adjustable positions within the tank.
The disadvantage is that some electronics is needed for a thermocouple because their output is in the millivolt range.
If all you need is the liquid level in the tank, there are ultrasonic sensor systems that install in the top of the tank and measure the distance to the fluid level.
Another possibility that may or may not work for you: There is usually (always?) a temperature difference of a couple degrees on the tank walls depending on whether there is liquid or vapor at that level. One implementation is a stick-on strip of a Liquid Crystal thermometer strip; unfortunately the ones I've run across need a human to read them.
A variation on finding the liquid/gas boundary is placing some heater+temperature sensors on the outside wall. The liquid will conduct the thermal energy away faster that the vapor will. That results in the sensors at the liquid showing a lower temperature that the ones at the gas level.
Another possibility (maybe the simplest) is two pressure gauges, one at the top of the tank and one at the bottom. Read the bottom pressure, subtract the top pressure, and you end up with the hydrostatic pressure of the liquid. Knowing the density of the liquid, you can calculate the liquid depth.
Well, that's my off-the-cuff brain dump on the subject.
When you get something working please let us know. We like to learn too!
Cheers,
Tom
Likes Leopold89 and Juanda
  • #61
What are your initial conditions for the CO2 case you ran?
Temperature
Pressure
Mass
  • #62
You gave a lot of input. I don't understand how exactly I can insert a thermocouple into the tank, because as I understand it I would need an empty tank. But I get full tanks from the manufacturer and did not see him offer these thermocouples.
Temperature
Pressure
Mass
I first computed the specific heat from the change in specific internal energy and ##h_\mathrm{out}## from the change in specific enthalpies ##h_{i-1} -h_{i}##, so I got a n-1 long time series. Then I passed on the temperature and pressure without the first entry and calculated the initial mass with the equation for ideal gases given the second temperature-pressure pair in the time series.
  • #63
All I'm asking for are the initial conditions in the tank (initial parameter values).
  • #64
##T=297.138375\mathrm{K}, p=5438467.5\mathrm{Pa}, m_0= 4.84398743373488\mathrm{kg}##
  • #65
At that temperature, the equilibrium vapor pressure of CO2 is 6.3 MPa, not 5.4 MPa. Are you saying that, initially, you have all vapor below the saturation pressure?
  • #66
Leopold89 said:
Not in all tanks, but in one I believe yes. For most chemicals I did a mistake like for CO2, where I followed Wiki, where they said you have liquid carbondioxide above 5.2bar and below 31°C, but after Chestermiller's explanation, I have corrected my mistake.
Yes. After your explanation I checked my data over the last three months and found that for example the CO##_2## tank has a maximum pressure of 6.1MPa.
  • #67
Leopold89 said:
4.84398743373488 kg
If you need to know the mass to a picogram, we can stop right now. Not going to happen.
  • #68
297 K and 5.4 MPa are inconsistent with 4.84 kg iii a 20 liter tank.
You initially have a superheated vapor, and the gas in the tank decreases in temperature and pressure isentropically as the tank empties until you hit the equilibbium bell. At that point, a liquid phase begins to form.
  • #69
I was just copy-pasting python output. It is not meant as desired precision.
  • #70
4.84 kg is not consistent with 50 liters, 297K and 5.84 MPa either.
  • #71
I tried something new and corrected the measured pressure of the CO##_2## tank with the atmospheric pressure. I expected to see a saw like pattern and hopefully small peaks dissapear, but got the plots attached here. The x axis is the Unix epoch time and the y axis is the difference between tank pressure and atmospheric pressure. Unfortunately the atmospheric pressure sensor is some 300 meters apart from the tanks.
I am rather discouraged, because we see a rising pressure over a few days and over three months the pressure difference never gets to 0, where I expect a change of tanks to have happened.
Maybe the whole experimental setup is faulty and needs revisiting?
  • #73
Leopold89 said:
Yes. After your explanation (from ChesterMiller) I checked my data over the last three months and found that for example the CO##_2## tank has a maximum pressure of 6.1MPa.
From this data, we have established that the mass is initially all in the gaseous state according to this table of saturated ##\mathrm{CO_2}## because at 24ºC (297 K) you're below the saturation pressure.
I'm not yet ready to study the evolution of the system as you discharge the content of the tank but I think I can calculate the initial mass from the experimental data you have.
Leopold89 said:
I'm using a different approach to the one you used there and got a different result too.
Using the ideal gas law being so close to the saturation bell doesn't give accurate results but there is an adapted formula for that.
The critical-point of ##\mathrm{CO_2}## is ##P_{cr}=7.39 \ \mathrm{MPa}## and ##T_{cr}=304.2 \ \mathrm{K}##.
Therefore, from your data, the reduced pressure and reduced temperature are:
$$T_R = \frac{T}{T_{cr}}=\frac{297.1}{304.2}=0.98$$
$$P_R = \frac{P}{P_{cr}}=\frac{5.43}{7.39}=0.75$$
So your compressibility factor ##Z## should be around ##Z=0.64##.
From the definition of ##Z##, it is possible to obtain the specific volume of the gas.
(Using SI units whenever units don't cancel)
$$Z = \frac{Pv}{RT} \rightarrow v = \frac{ZRT}{P}=\frac{0.64*188.9*297.1}{5.43*10^6}=0.006615 \ \mathrm{m^3/kg}$$
Lastly, knowing the tank's volume is ##V = 0.05 \ \mathrm{m^3}## we can find the actual mass.
$$v=V/m \rightarrow m=V/v=\frac{0.05}{0.006615}=7.56 \ \mathrm{kg}$$
I'm not sure if it's my first or second time in my life doing these calculations but I followed the book "Thermodynamics An Engineering Approach" by the letter so I believe it'd be OK. Feel free to point out any errors or comments.
  • #74
As long as the content inside the tank is entirely gas, the approach from #73 should be valid—assuming what I wrote there is correct. Since you have pressure and temperature data from your sensors, you have all the information needed to determine the mass, which I believe is your primary concern. If you can incorporate the compressibility factor into your Python code, you'll be able to calculate the mass at each time step.
It would be helpful to add checks in your code to ensure that, as it runs, it verifies whether you're inside or outside the saturation bell. This way, you'll know if you're using the correct set of equations. Since the starting point doesn't have enough pressure to condense the gas, and you're releasing pressure over time, I believe you'll be able to use these equations most of the time because, once thermal equilibrium is reached, the content will likely be entirely gaseous.
I believe those green curves defining ##Z## correspond to a 3D surface ##Z(P, T)##. If you can find this surface, it should be fairly straightforward to add it to the code. If not, you could try approximating it with the level of detail necessary for your application.
  • #75
$$T_R = \frac{T}{T_cr}=\frac{297.1}{304.2}=0.98$$
$$P_R = \frac{P}{P_cr}=\frac{5.43}{7.39}=0.75$$
This is much better. Another approach would be to use the conditions in the table that are close to the initial temperature and pressure to estimate z: T=297 K, P=6.29 MPa, v=0.004327 m^3/kg=0.00019039 m^3/mole
$$z=\frac{(6290000)(0.00019039)}{(8.314)(297)}=0.49$$
  • #76
Like I said earlier, the vapor for the initial condition of CO2 is superheated. Therefore, as the tank begins to expel gas, the gas remaining in the tank will experience an isentropic expansion until the 2 phase envelope is readhed. Moran et al, Fundamentals of Engineering Thermodynamics, presents a pressure-enthalpy diagram for CO2 that can be used to follow the isentropic line down to the 2 phase envelope.
  • #77
Is this the diagram you're referring to? It says R744 but that should be the same as CO2.
I'm still unsure of how to solve it but, from what you said, I can find the starting point from the known pressure and temperature.
Once it starts discharging, follow the isentropic line reducing pressure up to the new point read by the sensor.
From that, it'd be possible to know the vapor quality right after the release so we can find the portion of liquid and volume inside the tank. The densities of both are known since it's saturated and pressure and temperature are known so it's possible to calculate the mass.
During that process, I think I'd ignore the temperature sensor. We're already assuming it's got the same entropy so the temperature data is not necessary. My reason for ignoring it is its readings are indirect. I'd trust it when it has enough time to reach thermal equilibrium but not in cases like this.
We assumed an isentropic expansion which I believe also means it's adiabatic. It can be assumed that the heat input is not too significant during the discharging process. However, once the release is done and time passes, the tank will keep absorbing heat from the room because it's significantly cooler. As it absorbs heat, all the content will be transformed into gas now that the pressure is lower so it'd be possible to calculate the mass again but using the compressibility factor as mentioned in the previous post.
All this process (this and the procedure from post #73) completely bypasses the need for differential equations. However, to calculate everything in your Python code from your sensor data you'd need to add the functions from the diagrams we used. That is:
  • ##Z(P, T)##
  • All the properties that define the p-h diagram with the isolines.
PS.
In a closed system with a known mixture of saturated liquid and vapor at a known fixed volume, if I add a known amount of heat, what process does the mixture undergo? It can't be isochoric because, for that to happen, the system would need to be 100% vapor from the start. This detail is irrelevant for this exercise because sensors are available to obtain the necessary data (P and T). However, could I determine the path the mixture follows within the bell curve while heat is added at a fixed volume?
Perhaps I should start a new discussion to explore this point in more detail, rather than complicating this one further.
  • #78
Juanda said:
Before diving into thermodynamic properties and equations, would it be possible just to weigh the loaded and unloaded tank?
The way this thread is going, it looks like that 'future' is rapidly approaching!
Since the tanks are from an outside source, try getting a scale for one of the tanks and have a tank delivered to it (or moved to it). Maybe you will have to make room somewhere, or put it in an inconvenient spot. Try it out to see how well it works.
You may even be able to rent a scale for testing.
Your product supplier will likely know how heavy a full tank is, and maybe an empty one too.
If your tanks are currently placed on a stand of some sort, maybe putting some strain gauges on the stand would turn them into a scale.
The strain guages measure the deflection of the stand, which is proportional to the weight.
I have also seen tanks for several thousand gallons of product being weighed by using a balance. They rest on a platform (or stand) mounted on a long bar. The pivot point is close to the tank and the bar extends several feet past the pivot. Then enough standard weights are hung on the far end of the bar to balance the tank weight. Think 'balance scale'.
Cheers,
Tom
  • #79
Yes.
Once the tank contents reaches the 2 phase region, the behavior of the contents remaining in the tank is no longer isentropic. This is because pure vapor is being removed from the valve, rather than a representative mixture of liquid and vapor from the tank. That was the idea of the analysis I did.
  • #80
  • ##Z(P, T)##
PS.
I used the Python package gascompressibility for the compressibility factor and got ~0.61 for the initial values. I calculated the spezific enthropy based on the initial values and then assumed it stayed constant and then calculated the temperature based on pressure and spezific enthropy, all using pyromat. From this calculated temperature I computed the compressibility and used the formula in post #73. In the below plots you see the result in the bottom right corner. Bottom left is the ODE solution with different initial mass based on my 0.61 compressibility. Changing the initial mass manually to the ~7.6kg does not change the shape and just shifts the plot down. The middle graph on the right is based on this. The middle graph on the left is the calculated temperature with constant spezific enthropy. I also checked for the liquid phase with interpolation and can confirm that in this data set no liquid is formed.
We can see that the temperature based on constant spezific enthropy is larger than room temperature T_T
[CODE lang="python" title="Python code for temperature calculation"]pyromat.config['unit_pressure']='Pa'
pyromat.config['unit_temperature']='K'
co2 = pyromat.get('ig.CO2')
isentropicTemperature = co2.T(p=pressureData, s=co2.s(T=temperatureData[0], p=pressureData[0]))[/CODE]
  • #81
I guess that small difference is acceptable. I was eyeballing the values from the diagram. Python takes the exact values from the data.
Did you need to calculate the entropy? I would have expected that value to be taken from a table. Or taken from a Python library just like ##Z##.
Secondly, did you read Chester's input on #79? What I did to describe the expansion of the content of the tank is only valid when we're outside the bell and it seems that you'd go into it during the isentropic expansion.
However, I still think you'd be able to calculate the mass as thermal equilibrium is reached as explained in #77.
From the equations I proposed you may not be able to calculate the mass when it's inside the bell as explained by Chester. You'd need the equations he proposed before but I don't understand them yet. I need to invest more time in them.
However, as soon as the content fully evaporates (which should do so as it absorbs heat from the ambient), you can repeat the process you did to find the initial mass when it was all vapor.
In summary, assuming that
  • you're mainly interested in the mass content of the tank and
  • the elapsed time between discharges is long enough for the content to evaporate completely
you could ditch the differential equations and calculate the mass of the tank using the compressibility factor from the readings produced by your sensors. The most accurate mass readings would be done right before the discharges since that's when the tank has had the most time to achieve thermal equilibrium so you can be sure the content is 100% vapor.
You wouldn't be able to have nice plots regarding how the mass content varies continuously with time but that data is irrelevant in the first place, right?
Your mass diagram would look something like this:
  1. The initial point we have established is known and it's all gas.
  2. Assuming 1 was already in thermal equilibrium with the room, from 1→2 nothing happens. If it wasn't in thermal equilibrium, we could have calculated the mass at 2 where, since enough time to evaporate completely has elapsed, the compressibility can be used. Since mass is conserved between 1 and 2, the mass is the same.
  3. The process 2→3 is a discharge. Hard stuff to do. At 3 there most likely is a mix of liquid and vapor within the tank due to the cooling effect of the isentropic expansion. I'll choose to ignore that process because I don't have the knowledge to tackle it yet. The important point to notice is from 3→4 the mass is preserved. Remember, mass is what we care about due to how the problem was originally defined and reiterated during the thread.
  4. The mass can be calculated at 4 because enough time has passed for the tank to reach thermal equilibrium at room temperature. Or at least, it has absorbed enough heat to completely evaporate its content.
  5. The process 4→5 is an intake. Since we have established the content at 4 is all gas, I believe this process can be assumed to be an isentropic compression of the previous content. However, that's not relevant to calculate the mass which is what we care about. At 5, the content should all be gas so you can use the previous equation again.
  6. The valves are closed from 5→6 so mass is preserved. Still, you can calculate the mass again to compare it with 5 because it's all gas just in case to check your numbers.
Remember, what I'm proposing should work because of the starting conditions you mentioned about your CO2 tank. Even in its historical peak pressure, at thermal equilibrium with the room, it's all gas. As long as you're below that, this method could be a good enough approximation for the mass content of the tank.
  • #82
Juanda said:
Did you need to calculate the entropy? I would have expected that value to be taken from a table. Or taken from a Python library just like Z.
As I wrote, I used the pyromat library for this.
For the bell check I used this CO##_2## table attached here and interpolated it with
scipy.interpolate. This way I get a pressure for a given temperature and can check if the measurements are below this limit. If not the program aborts.
  • #83
That is the problem. I tried to find the time frames, where no discharge was happening by subtracting atmospheric pressure and gas pressure, but I did not get time frames with constant pressure.
  • #84
All right. You said calculate so I thought you were getting the value through other means.
I tried plotting some values from the document you provided and it seems accurate when I compare it to plots from the internet.
Where did you get that table?
Your sensors are reading the pressure inside the tank. Why are you trusting the temperature sensors in each time step instead? Due to your set up, they are indirect measurements of the tank.
I would rather trust the pressure sensors and only trust the temperature sensors when enough time has passed between discharges.
Also, are you saying your code doesn't register you're going inside the bell? I find it surprising because the initial conditions were very close to the bell but if you're always outside it makes the calculations simpler. You can use ##Z## all the way.
  • #85
How is the valve actuated? If it's electronically actuated, you can add the information to the time history.
Otherwise, even if you're not seeing when pressure is constant, you're seeing sudden peaks in pressure which should correspond to the charges and discharges. Try calculating the derivative ##\frac{dP}{dt}## and when it goes beyond a certain threshold you can assume it's a discharge/charge process. You'll have to tweak that threshold for both processes but it might work. Hopefully, the changes introduced by the valves admitting or outputting gas will be faster than the changes introduced by the system trying to reach equilibrium once the valves are closed.
If you're not seeing time intervals where pressure and temperature are constant it means the content has not had enough time to reach equilibrium. That's all right because we don't need it to be in equilibrium for our calculations, we just need it to be 100% gas.
I think the main thing you're missing is a reliable temperature sensor inside the tank.
  • #86
When you have 2 phases present inside, knowledge of the inside pressure tells you the inside temperature since the heat transfer is slow and the contents are thus very close to thermodynamic equilibrium. You can then determine the mass of CO2 in the tank using the saturated CO2 tables which give the liquid and vapor specific volumes at each saturation condition.
I have trouble understanding how the mass of CO2 inside the tank can increase if the valve only discharges mass.
  • #87
First we assumed that the temperatures will get in an equilibrium fast and now with the isentropic approach I used calculated temperature values.
The valve is actuated mechanically. And the sudden, small peaks do not correspond to discharges, because we only discharge around two times a day, I just learned. (BTW the tanks do not get charged only discharged)
I also asked the manufacturer and it is not possible to get a temperature sensor inside the tank.
Edit:
"Where did you get that table?"
I copied it from an old German textbook.
  • #88
Maybe some implementation error. I post my code, too:
[CODE lang="python" title="Van-der-Waals-equation"]def vanDerWaals_a(inGas):
return 27/64.0*math.pow(constants.R*criticalTemperature[inGas], 2)/criticalPressure[inGas]
def vanDerWaals_b(inGas):
return constants.R*criticalTemperature[inGas]/8.0/criticalPressure[inGas]
def solveCubic(a, b, c, d):
delta0 = b*b-3*a*c
delta1 = 2*math.pow(b, 3)-9*a*b*c+27*a*a*d
if delta0 == 0 and delta1 == 0:
return -b/3.0/a
if delta0 == 0:
tempResult = delta1**(1/3.0)
else:
tempResult = ((delta1+cmath.sqrt(delta1*delta1 - 4*math.pow(delta0,3)))/2.0)**(1/3.0)
rotAngle = (-1+cmath.sqrt(-3))/2.0
result = []
for i in range(0,2):
result.append(-1/3.0/a*(b+(rotAngle**i) *tempResult + delta0/(rotAngle**i)/tempResult))
return result
def calcParticles(tData, pData, fileName, volume):
n_samples = len(tData)
gasData=readSteamTable(fileName)
pLimit = pchip_interpolate(gasData.t, gasData.p, tData)*bar
adjustedN=np.zeros(n_samples)
a = vanDerWaals_a(Gas.CO2)
b = vanDerWaals_b(Gas.CO2)
for i in range(0,n_samples):
if pData<pLimit:
tempResult = solveCubic(1, -volume/b, (pData+constants.R*tData/b)*volume*volume/a, -pData*math.pow(volume, 3)/a/b)
if checkRoots(tempResult):
for root in tempResult:
if abs(root.imag)<1e-12 and root.real>0:
adjustedN=root
else:
sys.exit()
else:
sys.exit()
return adjustedN[/CODE]
This result is multiplied with ##0.0440098\frac{\mathrm{kg}}{\mathrm{mol}}##.
[CODE lang="python" title="Compressibility Approach"]def CalcCompressibility(tData, pData):
z=[]
gasData=readSteamTable("CO2_table.txt")
for i in range(0,len(tData)):
if pData<pLimit:
z.append(gc.calc_z(T=kelvinToFahrenheit(tData), P=pData*0.0001450377, Tr=tData/criticalTemperature[Gas.CO2], Pr=pData/criticalPressure[Gas.CO2]))
else:
sys.exit()
return z
masses = []
for i in range(0,len(z)):
masses.append(volume/(z*constants.R*isentropicTemperature/pressureData)*0.0440098)[/CODE]
And lastly:
[CODE lang="python" title="ODE"]def massDerivative(y, t, temperature, temperatureDot, pressure, hData, qData, qDotData, timeData):
index = 0
for i in range(0,len(timeData)):
if t<timeData:
index = i
break
specHeatCap = co2.cv(T=temperature[index], p=pressure[index])
nom = (qDotData[index] - specHeatCap*temperatureDot[index])*y
denom = specHeatCap * temperature[index] - hData[index] - qData[index]
result = nom/denom
return result
uData = co2.e(T=temperatureData, p=pressureData)
hData = co2.h(T=temperatureData, p=pressureData)
timeData = np.linspace(0, 2*(len(temperatureData)-1), len(temperatureData))
hOutData = []
qData = []
for i in range(1, len(uData)):
qData.append(uData[i-1] - uData)
hOutData.append(hData[i-1] - hData)
qDotData = np.gradient(qData, timeData[1:])
tDotData = np.gradient(temperatureData, timeData)
initialMass=0.0440098*volume/(z[1]*constants.R*isentropicTemperature[1]/pressureData[1])
sol = odeint(massDerivative, initialMass, timeData[1:], tfirst = False, args=(temperatureData[1:], tDotData[1:], pressureData[1:], hOutData, qData, qDotData, timeData[1:]))
[/CODE]
Here the z[1] is the same as in the previous code block.
Edit: I forgot to use the isentropic temperature in the ODE approach but now attached the version using calculated temperature.
  • #89
Just to be clear, when you post these graphs, temperature and pressure are calculated from initial conditions or are they the values straight from your sensors?
(By the way, you'd be able to copy-paste pictures instead of attaching them if that's more comfortable for you)
You mentioned you have sensors for pressure and temperature. (Even if the temperature is not really from inside the tank, we can address that later)
Can you upload those graphs if you haven't done it already? Because I really can't understand how it's possible that, even if you're ONLY discharging from the tank, we're seeing how pressure rises. Nor I can understand where the jagginess of the curve comes from. I'd expect sudden changes when the valve is open and the smooth behavior towards the new equilibrium point. Could it be electrical noise?
How long does the discharge take? Could you plot the temperature and pressure readings for a couple of days or so? It's to try to guess where are those 4 discharges (2 discharges/day) that you mentioned.
Can you add units to the horizontal axis?
  • #90
Sorry about the x-axis. I wrote that measurements take place every 2 minutes, so I got lazy and omitted the x-axis. The first row is direct sensor data for temperature and pressure. The x axis is the same for all plots, which is why I now only wrote it at the bottom.
The jagginess is only observable in CO##_2## and not in any other gas, but you see the same jagginess in all two CO##_2## tanks. That is why I think a defect or noise is unlikely, but on the other hand the other gases do not show this pattern. The slow rising pressure is, as far as I understand, the result of weather. Guessing the discharges might be difficult, because small amounts of this one gas are discharged.
The jagginess might also be only of secondary concern, because if the mass is calculated correctly, you should be able to smoothen this pattern away.
  • #91
OK. So the long-term trends could be influenced by the weather. Would it be possible to plot this with a timestamp (e.g., day, hour, minute, or just day and hour)?
It would be feasible if you know the time at each time step, or you could assume the peak temperature represents the hottest time of day to see if that provides a clear pattern.
It might also help to understand how heat is transferred to the tank. For instance, I'd expect the tank temperature to rise around 15:00 when the room temperature is highest.
In addition to the temperature sensor you've mentioned, do you have another one to monitor the room from which the tank is absorbing heat?
However, those sudden pressure increments don't make sense. I can't figure out what's causing them. I could understand sudden drops in pressure if you're opening the valves to release pressure, but not the opposite. And even that should not cause such jaggedness since you mentioned that the valves only open a couple of times a day.
Can you find out how long the valves remain open? Is it a matter of seconds, minutes, or hours? You said they release small amounts, but I want to see if these releases could overlap with the long-term trends we're attributing to the weather.
Finally, can you share your pressure and temperature (P and T) data from the last plot in the same format you previously used to share the saturation bell for CO2? Ideally, with the timestamp included as well.
  • #92
How can the mass increase if the tank is only vented.
Likes Vanadium 50 and Juanda
  • #93
Here is the kind of pressure regulator I am using to vent gas, but in German. Mass should therefore not flow inside. I would not think mass is increasing, but instead that too many simplifications were made or a miscalculation happened somewhere, which is why I posted my code.
If mass increases, ##\Delta m \propto \frac{p_1}{T_1}-\frac{p_2}{T_2}##, I would guess that either the pressure ##p_2## is smaller than it should be or the temperature ##T_2## is larger than it should be. The last case makes sense and for me it means that the heat transfer from room to gas takes time that is not negligible.
Another one of my fruitless ideas is to plot a histogram of enthropy or enthalpy. After each release the peak should move further away and this new expectation value could be used to determine the system variables in equilibrium, but the enthalpy curve looks just like the temperature curve.
  • #94
With that kind of valve, the mass flow should only be towards the exit (only discharges happening).
And it should only depend on the forces ##F_1## and ##F_2## which are defined by the difference in pressure between the chambers (inside the tank and room pressure for simplification) and the springs installed.
In summary, once the pressure tank goes beyond a certain pressure limit defined by the ambient pressure and the springs, the valve will open.
In this case, since the input energy that could cause the valve opening simply comes from the heat in the room, I believe the released mass will be very small until pressure equilibrium is reached again.
The content of the tank might not even go inside the bell because of how small is the release. As you suggested in a previous post your program is not aborting the calculation so the content seems to be 100% gas all the time.
Leopold89 said:
For the bell check I used this CO##_2## table attached here and interpolated it with scipy.interpolate. This way I get a pressure for a given temperature and can check if the measurements are below this limit. If not the program aborts.
So you might release some mass at the beginning when the tank is full but you won't release any mass in future days because the heat input from the room won't be enough to increase the pressure to the point to force the valve opening again now that there is less mass inside. This is unless the next day is significantly hotter than the previous day.
Again, if you supply your temperature and pressure data I'd like to attempt to calculate the mass myself only using the compressibility factor ##Z##.
Assuming that the content doesn't turn to liquid, you don't need differential equations to know the mass at any moment. The procedure established in#73 should suffice. I don't understand why you're using Van-der-Waals-equation and ODEs.
And even if it does transform to liquid during discharges, you could calculate the mass assuming it doesn't. You might get weird values in the time steps where there is liquid in the chamber but that liquid should turn into gas soon so you should see periods of time where the mass is constant which correspond to those times where there is 100% gas in the tank and the valves are closed. However, your pressure and temperature sensors must give you reliable data for that calculation to be accurate.
  • #95
Let’s see what you get if you plot the measured outside temperature at time t as a function of the measured inside pressure at time t.
  • #96
In above plot I believe to see how the temperature is maximal between 12:00 and 16:00, but the pressure is maximal at around 16:00, maybe a little later than the temperature.
Do you mean the room that affects the pressure regulator? I don't think the cable is long enough to get the second one there.
Did you mean something like this? The z-axis is still time in minutes though.
I switched the axes, because it fits better with the phase diagrams I know. Orange is the interpolated vapour-liquid-limit from my table.
Juanda said:
Again, if you supply your temperature and pressure data I'd like to attempt to calculate the mass myself only using the compressibility factor Z.
Oh, I thought you meant plots, not a data file. Attached here.
  • #97
Leopold89 said:
For the bell check I used this CO##_2## table attached (...)
What's the meaning of ##r##?
I think I don't need it for the way I want to solve it but I'd like to know.
  • #98
This graph seems to suggest that, since the pressure is less than the equilibrium vapor pressure at each temperature, the gas is always superheated. That would mean that there is a single phase at all times. (I assume you have plotted the absolute pressures, not the gauge pressures, which are 0.1 MPa lower). Under these circumstances, the equation of state indicated by Juanda applies: $$\frac{m}{V}=\frac{PM}{zRT}$$where m is in grams, and R=8.314 J/mole-K. So you can calculate how m varies with time in your example (assuming the temperature in the tank has equilibrated with the outside temperature at each time). What do you calculate?
  • #99
Oh, no. I plotted the gauge pressures. The absolute pressures are only in post #71.
I calculate precisely this in post #88. It is the bottom right graph.
  • #100
That could change the problem significantly. I did everything assuming we're talking about absolute pressures.
If that's true, then all I can think of is two things:
  • either the new data regarding absolute pressures changes the problem significantly because you're inside the bell although you mentioned you're checking if that's the case and it seems it's gas all the time
  • or your sensors are not accurate.
My bet is that your temperature sensor is not accurate to describe the gas' temperature since it's not inside the tank. Could you at least attach it to an outside wall of the tank and cover it with an insulating paste of some kind?
However, it's also true that the jaggedness is introduced by the pressure sensor... I really don't know what's going on and I'm running out of ideas.
Maybe some sort of resonance between the springs in the valve and the compressed gas? I'd be very surprised it's not dissipated quickly and also the period is too long. I'm throwing ideas to the wall and seeing what sticks at this point.
By the way, I didn't know you already tried my approach on post #88 so I did it too although I'm using the values from #73 where I assumed we're talking about absolute pressures.
In theory, the problem should be doable just with Pyromat because you can get the specific volume from the pressure and temperature but I got a different result compared to what was done in #73. I guess I'm not experienced enough with that library and I'm committing a mistake. I calculated the mass again using the gascompressibility library to find ##Z## (after a few awful unit conversions) and then I did get the same results as in post #73.
So the red one is the one I trust for now. I can't find what I did wrong with Pyromat because I told it to use the SI units.
I won't be able to invest more time in this for a few days. And even if I did I feel I have nothing else to add. I'll keep my eyes open in case the mysteries are solved somehow. Again, I think you'd get some actual temperature readings from inside the tank if you want to proceed with this method. If the manufacturer insists on it not being possible then you'll have to fight him or find an alternative method. Maybe even checking your pressure sensors to see if they're working correctly.
Here is the associated code and text file containing the pressure and temperature history.
NOTE: I once tried to copy code from the Forum to Spyder and it didn't work very well. If you have that issue, try pasting it on ChatGPT and it'll give you the code back in a format you can easily paste on Spyder.
[CODE lang="python" title="MassCalculation"]import pandas as pd
import numpy as np
import matplotlib.pyplot as plt
import pyromat as pm
import gascompressibility as gc
pm.config['unit_pressure']='Pa'
pm.config['unit_temperature']='K'
pm.config['unit_mass']='kg'
pm.config['unit_volume']='m3'
co2 = pm.get('ig.CO2')
V = 0.05 # Tank's volume [m3]
# Specify the path to the file
# Pressure and temperature at a given time step by the sensors
file_path_1 = 'D:\Datos de Usuario\Descargas\SmallDataSet_Juanda.txt'
dataPTt = pd.read_csv(file_path_1, sep=';')
Time_sensor_array = dataPTt['Time [date, hour]'].to_numpy() #[date, hour]
Temperature_sensor_array = dataPTt['Temperature [K]'].to_numpy() #[K]
Pressure_sensor_array = dataPTt['Pressure [Pa]'].to_numpy() #[Pa]
def create_incrementing_array(input_array):
# Measure the size of the input array
size = len(input_array)
# Create a new array starting from 0 and incrementing by 2 until it's the same size as the input array
new_array = [i * 2 for i in range(size)]
return new_array
Time_sensor_array_2min = create_incrementing_array(Time_sensor_array)
# Using pyromat to find the specific volume [m3/kg]. It gives of a different result than in post #73 using compressibility (I thought it was absolute pressures)
Specific_volume_pyromat = co2.v(T=Temperature_sensor_array, p=Pressure_sensor_array) #[m3/kg]
# print(Specific_volume_pyromat[0])
m_pyromat = V/Specific_volume_pyromat
P_cr_CO2 = 7.39*10**6 # Critical pressure (top of the bell) [Pa]
T_cr_CO2 = 304.2 # Critical temperature (top of the bell) [K]
R = 188.9 # Gas constant [J/kgK]
P_R_CO2 = Pressure_sensor_array/P_cr_CO2
T_R_CO2 = Temperature_sensor_array/T_cr_CO2
Pressure_sensor_array_PSGI = (Pressure_sensor_array-(0.1*10**6))/6895
Temperature_sensor_array_F = (Temperature_sensor_array - 273.15) * 9 / 5 + 32
Z_0 = gc.calc_z(sg=1, P=Pressure_sensor_array_PSGI[0], T=Temperature_sensor_array_F[0], H2S=None, CO2=1, N2=None, Pr=P_R_CO2[0], Tr=T_R_CO2[0], pmodel='piper')
# print(Z_0)
def compute_compressibility_factors(pressure_array, temperature_array, Pr_array, Tr_array):
Compute the compressibility factor Z for each coordinate in the input vectors.
Parameters:
- pressure_array: Array of pressure values in PSGI.
- temperature_array: Array of temperature values in Fahrenheit.
- Pr_array: Array of reduced pressures for each coordinate.
- Tr_array: Array of reduced temperatures for each coordinate.
Returns:
- A NumPy array of compressibility factors Z.
# Compute Z for each coordinate and collect the results in a list
Z_list = [gc.calc_z(
sg=1,
P=pressure_array,
T=temperature_array,
H2S=None,
CO2=1,
N2=None,
Pr=Pr_array,
Tr=Tr_array,
pmodel='piper'
) for i in range(len(pressure_array))]
# Convert the list of Z values to a NumPy array
return np.array(Z_list)
Z_values = compute_compressibility_factors(
Pressure_sensor_array_PSGI,
Temperature_sensor_array_F,
P_R_CO2,
T_R_CO2
# print(Z_values[0])
# Using compressibility (import gascompressibility as gc) to find the specific volume [m3/kg]. I get the same as in #73 (assuming absolute pressures)
Specific_volume_compressibility = (Z_values*R*Temperature_sensor_array)/Pressure_sensor_array #[m3/kg]
m_gascompressibility = V/Specific_volume_compressibility
# print(m_gascompressibility[0])
# Ensure Time_sensor_array_2min has the same length as m_pyromat and m_gascompressibility
# If Time_sensor_array_2min does not match the lengths of m_pyromat and m_gascompressibility, adjust accordingly.
# Create the plot
plt.figure(figsize=(12, 6))
# Plot m_pyromat
plt.plot(Time_sensor_array_2min, m_pyromat, label='m_pyromat', color='blue', marker='o')
# Plot m_gascompressibility
plt.plot(Time_sensor_array_2min, m_gascompressibility, label='m_gascompressibility', color='red', marker='x')
# Add labels and title
plt.xlabel('Time (min)')
plt.ylabel('Mass (kg)')
plt.title('Comparison of Mass Calculated with pyromat and gascompressibility')
plt.legend()
plt.grid(True)
# Display the plot
plt.show()[/CODE]
