How to calculate the series ##\sum_{x = 1}^{\infty} \frac{sin(x)}{x}##
  • Thread starter Thread starter shrub_broom
    Series
shrub_broom
I have known how to calculate the integral##\int_{0}^{\infty} \frac{sin(x)}{x}##, however I find it hard to calculate this one since the similar technique(by parametric integral) cannot be simply applied on series.
Any approach or hint is welcomed.
##\sum_{x = 1}^{\infty} \frac{sin(x)}{x} = \frac{\pi - 1}{2}##
Maybe introduce a parametric factor can be help.
Is this homework ? Some activity on your part is required in PF guidelines
No, just for fun.
shrub_broom said:
Problem Statement: I have known how to calculate the integral##\int_{0}^{\infty} \frac{sin(x)}{x}##, however I find it hard to calculate this one since the similar technique(by parametric integral) cannot be simply applied on series.
Relevant Equations: ##\sum_{x = 1}^{\infty} \frac{sin(x)}{x} = \frac{\pi - 1}{2}##
You could try replacing ##\sin(x)## with it's representation as an infinite product.
Express the sine in terms of complex exponentials.
Likes haruspex
Similar thread:
fakecop said:
Determine whether the series Ʃ(1 to infinity) sinx / x converges or diverges.
This question appears in the integral test section, but as far as i know the integral test can only be used for decreasing functions, right?
Using the ratio test, limx->infinity sin(x+1)/(x+1)*(sinx/x)=limx->infinity x*sin(x+1)/((x+1)(sinx))
This is where i got stuck-this limit oscillates between positive infinity and negative infinity.
Using the root test, i need to find the limit of (sinx)^(1/x) as x approaches infinity, which also gets me nowhere.
we have not done taylor series yet so I'm sure there is a relatively simple approach to this question...please help?
Your integral is egregiously improper. You must normalize it by redefining the function ## sinc(x)=1## when ## x=0## and ##sinc(x)= \frac{sin(x)}{x}## when ## x\neq 0##. Please see wikipedia page on sinc function.
BvU said:
Similar thread:
Yes, but that is not looking for the value. @vela's method works.
Likes BvU
