How to Calculate Translational Kinetic Energy of a Gas Using Ideal Gas Law
To calculate the total translational kinetic energy of 0.5 L of oxygen gas at 0°C and 1.3 atm, the ideal gas law (PV=nRT) is used to determine the number of moles of gas. The translational kinetic energy can be expressed as K = (3/2)nRT, which simplifies the calculation. Substituting the values for pressure and volume into the ideal gas law allows for the determination of moles, which can then be plugged into the kinetic energy equation. This approach clarifies the relationship between the ideal gas law and translational kinetic energy. Understanding these connections simplifies the problem-solving process.
KsonGV
1.Find the total translational kinetic energy of 0.5 L of oxygen gas held at a temperature of 0°C and a pressure of 1.3 atm.
2.
R = 8.314
PV=nRT
PV=NkT
K=(.5*m*v^2)
Translational Kinetic Energy = T=(2/3)(1/k)[(.5)mv^2]
3.
The problem says to express the total translational kinetic energy of the oxygen gas by combining the expression for the translational kinetic energy and the ideal-gas law to obtain an expression for K in terms of the pressure and volume of the gas.
I tried subsitituting T= PV/nR to T=(2/3)(1/k)[(.5)mv^2] but I am not sure if I am on the right track.
You can use PV = nRT to find the mols of oxygen gas you have. Then, you can use the translational kinetic energy equation for gasses, K = (3/2)nRT, to find K.
Oh. So i need to find the moles using the ideal gas law then plug it into the K equation. I was over thinking the whole problem.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
