How to complete this derivative proof?
Amad27
Assume that $f(x)$ has two derivatives in $(0,2)$ and $0<a<b<a+b<2$.
Prove that if $f(a)\ge f(a+b)$ and $f″(x)\le 0$ $\forall x \in (0, 2)$, then:
$$\frac{af(a)+bf(b)}{a+b} \ge f(a+b) \tag 1$$
Below
**MY PROOF:**
If $(1)$ is true then : $af(a) + bf(b) \ge af(a + b) + bf(a + b)$ , since it is given that: $af(a) \ge af(a+b)$ the objective is to prove: $f(b) \ge f(a + b)$
Assume $f(b) < f(a + b) $
$$\frac{f(a + b) - f(b)}{a} > 0 \tag2$$
For some $x$ the **Mean Value Theorem** guarantees for $\exists x_1 \in (b, a+b)$ that $$f'(x_1) = \frac{f(a + b) - f(b)}{a} $$
Hence, $(2)$ really means: $f'(x_1) > 0$ for some $x_1 \in (b, a+b)$
Since, $f(a) \ge f(a + b)$:
$$\frac{f(a + b) - f(a)}{b} \le 0 \tag3$$
By the **Mean Value Theorem,** $\exists x_2 \in (a, a+b)$ such that $$f'(x_2) =\frac{f(a + b) - f(a)}{b}$$
Hence $(3)$ really means, $$f'(x_2) \le 0$$
1. Obviously, if $f'(x_2) = 0$ then $f''(x_2)$ is a max, which means $f''(x_2) = 0$
2. Since $x_1 > x_2$ there $\exists x_3 \in (x_1, x_2)$ such that $f'(x_3) = 0$, which means $f''(x_3)$ is a max, meaning $f''(x_3) = 0$ contadictions.I just need help with 1 above, what if $x_2$ was a minimum?
Thanks!
If x2 is a minimum then f is constant if x2 is neither 0 or 2.
Amad27 said:
Assume that ##f(x)## has two derivatives in ##(0,2)## and ##0<a<b<a+b<2##.
Prove that if ##f(a)\ge f(a+b)## and ##f″(x)\le 0## ##\forall x \in (0, 2)##, then:
Below
**MY PROOF:**
If ##(1)## is true then : ##af(a) + bf(b) \ge af(a + b) + bf(a + b)## , since it is given that: ##af(a) \ge af(a+b)## the objective is to prove: ##f(b) \ge f(a + b)##
Assume ##f(b) < f(a + b) ##
By the **Mean Value Theorem,** ##\exists x_2 \in (a, a+b)## such that $$f'(x_2) =\frac{f(a + b) - f(a)}{b}$$
Hence ##(3)## really means, $$f'(x_2) \le 0$$
1. Obviously, if ##f'(x_2) = 0## then ##f''(x_2)## is a max, which means ##f''(x_2) = 0##
2. Since ##x_1 > x_2## there ##\exists x_3 \in (x_1, x_2)## such that ##f'(x_3) = 0##, which means ##f''(x_3)## is a max, meaning ##f''(x_3) = 0## contadictions.I just need help with 1 above, what if $x_2$ was a minimum?
Thanks!
Use ## \small{\text{ ## ___ ## }} ## for delimiters for inline LaTeX.
I fixed up some of it.
@RUber, is my proof correct though?
