I How to Convert Plummer Distribution of Stars Parameters into Standard Units?
  • I
  • Thread starter Thread starter jimbo007
    Distribution Stars
The discussion focuses on converting parameters from a Plummer distribution of stars into standard units, specifically for a simulation involving N stars of mass m within a defined volume. The user seeks clarification on how to convert the calculated positions (x, y, z) and velocities (u, v, w) into meters and meters per second. They reference a specific PDF document that outlines the Plummer density function and provide equations for generating star positions and velocities using random numbers. The user acknowledges understanding the calculations but struggles with the final conversion to standard units. The conversation highlights the need for clearer guidance on the conversion process for the star parameters.
jimbo007
Hi all,
I refer to the following pdf document, in particular the appendix:
http://adsabs.harvard.edu/cgi-bin/n.....37..183A&link_type=ARTICLE&db_key=AST&high=
End goal is to distribute N stars each having mass m (looks like equal mass stars is the easiest scenario) within a box who has each side of length 3 \times 10^{17} \text{m} so that the total mass is M. I think I understand that you can't get all stars in the box but as long as most are in the box that should be close enough.
There are some parts of this document I don't understand but will take on faith that it is true.
I do understand how the position (x,y,z) and velocity (u,v,w) are calculated but not sure how to convert them to metres and metres/sec.
Does anyone know how to convert each stars mass m, position (x,y,z) and velocity (u,v,w) into kg, m and m/s?
Thanks!
Astronomy news on Phys.org
I probably should at least put a few more equations into make things a bit easier. Plummer's density is given by:
\rho(r) = \frac{3M}{4\pi R^3}\left( 1+ \left(\frac{r}{R} \right)^2 \right)^{-\frac{5}{2}}
where
M = total mass of star cluster
R = magic scaling parameter
Now let X_{n} be a uniformly distributed random number between 0 and 1. (x, y, z) is the position of the star and (u, v, w) is the velocity of the star
<br /> \mathbf{x} = \begin{pmatrix}x \\ y \\ z\end{pmatrix} \\<br /> \dot{\mathbf{x}} = \begin{pmatrix} u \\ v \\ w \end{pmatrix}<br />
then
<br /> r = \left(X_{1}^{-\frac{2}{3}} - 1 \right)^{-\frac{1}{2}} \\<br /> z = \left( 1-2X_{2} \right) r<br />
x, y, u, v and w and calculated in a similar fashion. The last paragraph in the pdf says to multiply these variables by a few numbers but it's not clear to me how to convert z to metres
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
