How to deal with this equation involving a plus/minus term
  • Thread starter Thread starter Dixanadu
    Term
The discussion centers on understanding a complex equation involving a plus/minus term, specifically \dot{X}^{-}\pm X^{-\prime} and its transformation into a new equation. The original equation is presented with indices, and the author seeks clarification on how to derive the second equation from the first. A suggested approach is to separate the original equation into two distinct equations—one for the plus case and one for the minus case—then expand their right-hand sides and add them together. This method aims to clarify the transition between the two forms of the equation. The conversation emphasizes the importance of careful manipulation of indices and the application of Einstein's summation convention in the derivation process.
Dixanadu
Hey guys,
So I'm reading a textbook which has the following equation:
\dot{X}^{-}\pm X^{-\prime}=\dfrac{1}{4\alpha' p^{+}}\left( \dot{X}^{I}\pm X^{I\prime} \right)^{2}.
Please note that the +,-,I are indices. Then the author says:
\dot{X}^{-}= \dfrac{1}{4\alpha' p^{+}}\left( \dot{X}^{I}\dot{X}_{I}+X^{I\prime}X_{I}^{'} \right)
where the repeated up and down index is using Einstein's summation convention.
I have no idea how you can get this equation from the first one...can someone explain please?
Thanks...
Mathematics news on Phys.org
What happens if you write the first as two equations?
One with +, the other with -. Expand their right hand sides. Then add...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
