How to detect coloured strips digitall?
  • Thread starter Thread starter ther3x
To detect a colored red strip on a flywheel for counting rotations, a sensor can be positioned along the circumference to identify the red tape. Utilizing sensors from resources like the Society of Robotics can enhance detection capabilities. Alternatively, replacing the red tape with shiny aluminum foil allows for the use of a laser pointer and photodiode to detect reflections, indicating each revolution. If the flywheel is highly reflective, using dark fabric tape or matte paint can help differentiate the absence of reflected light. This approach provides a reliable method for digital counting of flywheel rotations.
ther3x
how to detect coloured strips digitall?
hi, how can i detect colored(red) strip of tape. This is required so that I can digitally count the no of rotations of a flywheell.
the thing is, the flywheel attached to the wall has a small red strip on its wheel. i need a sensor to detect that red strip as the flywheel rotates so that it can input data to the digital counter which counts those rotations.
so how can i use to detect red colored strip ..
please thanx
Welcome to PhysicsForums!
If there's a little red dot somewhere near the outside edge of this flywheel, you might be able to detect it using a sensor placed on the same circumference which utilizes some of the ideas here at the Society of Robotics:
http://www.societyofrobots.com/sensors_color.shtml
Now, if you can replace that red piece of tape with a piece of shiny aluminum foil (and assuming the room's dark) you can use a laser pointer (or laser diode) and photodiode to detect the reflected light (once per revolution). If the whole flywheel happens to be quite reflective, placing some dark fabric tape (or some matte black paint, or something similar) would allow you to detect the absence of reflected laser light whenever the patch crosses the sensor and absorbs the laser light.
Thanks :d
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
