How to determine a lens width?
  • Level: Undergrad
  • Thread starter Thread starter clalburn1420
    Lens Width
5 replies · 3K views
clalburn1420
I am wondering... say an object was put directly on a lens and you wanted the projected image to focus at around 3 cm on the other side. How do you determine how wide the lens has to be?
(please see attachment)
Ah, so it is also determined by the shape. However, i expect it would need to be a convergent lens type and assume it needs to be like a () shaped lens. The problem is however, that this equation can help find focal length but not describe how the lens itself will be shaped.
Placing an object directly in contact with a lens (any lens) is not a good way to form an image any finite distance away from the lens. Why do you want to do this?
Simply curious if its possible. I'm not sure it is, which is why I'm wondering. What about if the object is a very small distance from the lens, like say 1 mm. Can you focus the image on the other side 3 cm away?
