How to Determine the pH of a Water Sample?
The discussion focuses on determining the pH of a water sample, emphasizing that pH is a quantitative measure of acidity or alkalinity defined mathematically as pH = -log [H+]. It highlights the importance of using molar concentration rather than mass when calculating pH, as demonstrated through a calculation example that corrects initial errors. Additionally, the conversation touches on related concepts such as alkalinity and hardness, explaining that water hardness is linked to dissolved calcium and magnesium salts, which can be measured through complexometric titration. The importance of accurate definitions and calculations in water chemistry is underscored throughout the discussion. Understanding these concepts is crucial for accurately assessing water quality.
Luckeris
I have no idea how to solve this. Any info would be helpful.
What is pH definition?
Quantitative measure of the strength of the acidity or alkalinity of a solution.
That's s descriptive definition, there is also a specific, mathematical one, much more precise.
The mathematical definition of pH is a bit less intuitive but in general more useful. It says that the pH is equal to to the negative logarithmic value of the Hydrogen ion (H+) concentration, or
pH = -log [H+]
pH can alternatively be defined mathematically as the negative logarithmic value of the Hydroxonium ion (H3O+) concentration. Using the Bronsted-Lowry approach
pH = -log [H3O+]
pH values are calculated in powers of 10. The hydrogen ion concentration of a solution with pH 1.0 is 10 times larger than the hydrogen concentration in a solution with pH 2.0. The larger the hydrogen ion concentration, the smaller the pH.
when the pH is above 7 the solution is basic (alkaline)
when the pH is below 7 the solution is acidic
Luckeris said:
pH = -log [H+]
OK, can you use information provided and this equation to calculate pH?
pH = -log [H+]=-log[0.23*10-2]=2.638 ??
No, you need molar concentration, not mg/L.
m=0.0023g
M(H)=1g/mol
n=m/M=0.0023mol
c=n/V=0.0023mol/l ?
Luckeris said:
m=0.0023g
This is not equivalent to 2.3*10-2mg, but other than that you are on the right track.
Oh yeah mili- means *10-3 not *10-1
m=2.3*10-5g
M(H)=1g/mol
n=m/M=2.3*10-5mol
c=n/V=2.3*10-5mol/l
pH = -log [H+]=-log[2.3*10-5]=4.638
Is that it in terms of pH?
Yes. Perhaps too many significant figures, but that's correct approach.
Now, look for definitions of both alkalinity and hardness, and think how they apply.
Alkalinity - http://www.ehow.com/how_5328969_calculate-alkalinity-caco.html
Hardness - Water hardness is a measure of the amount of calcium and magnesium salts dissolved in water. There are no health hazards associated with water hardness, however, hard water causes scale, as well as the reduced lathering of soaps. Complexometric titration is one of the best ways of measuring total water hardness. Ca2+ + EDTA4- → CaEDTA2-
Indicator (Eriochrome Black T) should be used to determine the end point of titration. Water hardness is usually reported in terms of mg/L of calcium carbonate which could by found from the mass of titrant used.
Good starting point, compare this with the data you are given.
So I have Ca in mg/L which was found from CaCO3 + EDTA4- → CaEDTA2- + CO32- or not?
Close, but not exact. You don't have solid CaCO3, but dissolved one. While calcium carbonate is weakly soluble, it is not completely insoluble. In fact, there are no completely insoluble salts.
