How to draw integral with mathematica
3 replies · 11K views · last reply
EliasS
Hello,
is there a way to draw the volume of a triple integral?, and in different ways?(rectangular, cylindrical and sphere coordinates)
for example if the integral is
Triple integral in spherical coordinates: integral from 0 to 2π of integral from 0 to π/4 of integral from 0 to 3 of ρ² sen φ dρ dφ dθ.
what I want is to draw directly with the above formula
3D plot of a solid bounded by a spherical or conical surface with a rotation arrow labelled θ around the z-axis, axes labelled x, y and z with tick marks at -2, 1 and 2.
I have been struggling all day with this, because if for example I use something like Plot3D[Integrate[x... it will first solve the integral, which will become a constant and then draw that constant
Also there must be a way because in the calculus book I'm studying, in many exercises it ask you to draw the volume of the problem with a software tool
Thank you, I really need this
  • Triple integral in spherical coordinates: integral from 0 to 2π, integral from 0 to π/4, integral from 0 to 3 of ρ² sen φ dρ dφ dθ.
  • 3D coordinate axes with z vertical, x and y labelled, and a solid region shaped like a cone-like volume with curved top, marked with a rotation arrow labelled theta around the z-axis.
What you want to plot here is not the integrand nor the integral, what you want to plot is the limits of integration. I would use ParametricPlot3D or RegionPlot3D, but you will have to transform from spherical coordinates to Cartesian coordinates either way.
Thank you DaleSpam, now I can draw integrals in rectangular coordinates, for example, the integral
RegionPlot3D[-2 < x < 2 && -\[Sqrt](4 - x^2) < y < \[Sqrt](4 - x^2) && x^2 + y^2 < z < 4, {x, -2, 2}, {y, -2, 2}, {z, 0, 5}, PlotPoints -> 50, Mesh -> True, AxesLabel -> Automatic]
will draw
3D plot of a solid bowl-shaped region bounded below by the paraboloid z = x^2 + y^2 and above by z = 4, with axes x, y and z labelled and mesh lines on the surface.
but for spherical coordinates, I found the sentence SphericalPlot3D, which for example with
SphericalPlot3D[{1}, {\[Phi], 0, Pi/4}, {\[Theta], 0, 2 Pi}]
will draw
Mathematica 3D plot of a solid dome-shaped region, a spherical cap with a mesh of latitude and longitude lines, axes labelled from -0.5 to 0.5 and z from 0.8 to 1.0.
but I doesn't draw the cone underneath the sphere, my question is, is there a way to do that?
I thought something like saying to mathematica "draw me rho from 0 to 1 continuously ", and it would draw
Mathematica 3D plot of a solid region shaped like a spherical cap sitting on a cone, drawn as stacked horizontal slices with a mesh, with axis ticks from -0.5 to 0.5 and 0 to 0.8.
, but the cone being solid
thank you
  • 3D plot of a solid region bounded below by the paraboloid z = x^2 + y^2 and above by the plane z = 4, with axes labeled x, y and z, rendered as a Mathematica RegionPlot3D with a mesh.
  • Mathematica 3D plot of a solid region shaped like a spherical cap sitting over a stack of nested cone-shaped slices, with the layers narrowing downward to a point near the bottom.
  • Mathematica 3D plot of a solid dome-shaped region, a spherical cap rendered as a blue mesh surface on axes labelled from -0.5 to 0.5 in x and y and 0.8 to 1.0 in z.
  • 3D plot of a solid bowl-shaped region bounded below by the paraboloid z = x^2 + y^2 and above by the plane z = 4, with axes labelled x, y and z and tick marks from -2 to 2.
  • Mathematica 3D plot of a solid dome-shaped region with a mesh of latitude and longitude lines, axes labeled from -0.5 to 0.5 in x and y and 0.8 to 1.0 in z.
I'd use region plot and just use spherical coordinates. Its slower, and requires tweaking due to the angles but :
r = Sqrt[x^2 + y^2 + z^2];
\[Phi] = ArcTan[y/Abs[x]];
\[Theta] = ArcCos[Abs[z]/Sqrt[x^2 + y^2 + z^2]];
RegionPlot3D[
0 < r <= 3 && 0 < Abs[\[Theta]] < \[Pi]/4, {x, -5, 5}, {y, -5,
5}, {z, 0, 5}, PlotPoints -> 60, Mesh -> True,
AxesLabel -> Automatic, PlotRange -> {{-3, 3}, {-3, 3}, {-1, 5}}]
http://en.wikipedia.org/wiki/Spherical_coordinatesSame for cylindrical. You just have to do a coordinate conversion back to cartesian.
