I How to estimate total energy when dealing with beamsplitters
To estimate the total power entering a beamsplitter using reflected power measurements, one must first calibrate the system by measuring input, reflected, and transmitted powers at the same wavelength. The reflected power can then be related to the total input power using the known splitting ratio, assuming it remains consistent across measurements. In this case, with a reflected power of 1.32 nJ and a splitting ratio of 52:46, the total input power can be calculated. However, discrepancies in total power measurements suggest potential absorption losses in the beamsplitter that need to be accounted for. Accurate calibration and understanding of the beamsplitter's characteristics are crucial for reliable energy estimations.
nordmoon
I'm having a brain freeze right now and I need some help. :frown:
I have a 50/50 beamsplitter (non-polarizing) with 5% tolerance. Test measurement (with a laser at a certain wavelength) gave that I'm transmitting 5.36 units and reflecting 4.6 units (49.5 transmitted; 42.6% reflected). Units refer to a conversion unit of my detector that I can convert to nJ or W. Without the beamsplitter the total power is 10.82 units.
If you add up the reflected and the transmitted powers, I get in total 9.97 units (there seem to be some losses in the the glass), using this total value I get the corresponding transmitted and reflected to 53% and 46% respectively.
In another measurement (using another laser with the same wavelength as above) I can measure the reflected power P= 1,32 units. I need to know the total power coming into the beamsplitter. The transmitted is unknown in my setup since a camera is placed in this end. How can I determine the total energy from the 53:46 or 49.5:42.6 division by knowing the reflected percentage?
Couldn't you take out the beamsplitter and empirically measure both the transmitted and reflected, the same way you did with the first light source? Unless you want to assume that the percentage of absorption is always the same for both light sources, then there is no direct way to determine the amount of transmission.
Zz.
The point of the beam splitter is that I'm only measuring the reflected beam in my actual setup (since the transmitted beam goes into a camera). The laser has the same wavelength (and is the same type of laser) so it should be the same splitting ratio from unit to unit.
In the above I measured the reflected and the transmitted powers to determine the actual splitting ratio.
Questions is how can I determine the total power entering the BS by measuring the reflected power (and without measuring the transmitted power every time). Can't I determine this from the pre-measured ratio? If so, how can I do this?
Thanks
Thanks
If it is the same wavelength (which it appears to be), then you should be able to "calibrate" it using your first measurement. So such calibration must be done first at this particular wavelength, i.e. before you start the experiment, you need to measure the input power, the reflected power, and the transmitted power. You have to do all 3 because real beamsplitter (or crystal) absorbs some of the power. Then you have to explicit assume that, for a given power at the same wavelength, the ratio of reflected to input power remains the same. In fact, you have to assume the ratio of reflected to transmitted power also remains the same.
Zz.
Zz.
I agree. So my embarrasing question is if I get a reflected transmission of 1,32 nJ. How much is the input power if I have splitting ratio of 52:46 (T:R)?
This doesn't seem right: the beamsplitter is absorbing 10% of the incident power? That's very noticeable and would create observable effects (heating, damage, etc.).
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
