How to find inductance of a coil with two concentric ferromagnetic cores?
To find the inductance of a coil with two concentric ferromagnetic cores, one must consider the arrangement and relative permeabilities of the materials involved. The inductance formula L = μN²A/l applies, but the presence of an air gap complicates the calculation. It is suggested that the outer core may dominate the inductance due to its shielding effect on the inner core. When an air gap is present, it increases leakage inductance and reduces magnetizing inductance, which should not be neglected. The contributions of different materials can be weighted based on the areas they occupy within the coil.
jam1234
This isn't exactly a homework question so there aren't any data/numbers to work with. I just want to know what to do if there are two ferromagnetic cores inside a coil of wire, arranged as concentric cylinders. Or how to account for the air gap between the core and the coil?
L = μN2A/l
Should it be treat as a series circuit? Or maybe parallel? Or do you weight the contributions of the relative permeabilities by the fraction of the area inside the coil they occupy?
L = μN2A/l
Depending on the arrangement, I would guess that the outer core would dominate the inductance -- that is, very little of the B-field would be coupled to the inner core. The outer core would act as a shield for the inner core, IMO.
Do you have an application in mind?
Well for example to account for the ring of air around a metal core in a solenoid. In some cases this may not be negligible.
That's a different situation than the question in your original post (OP). If you have an air gap between the windings and a single core, then that increases the leakage inductance Lk and reduces your magnetizing inductance Lm.
I did put the air gap bit in my original question as well. How would you find the inductance of a coil with a metal core and an air gap around it? I don't want to assume it is negligible because it isn't always. Do you just use the relative permeabilities weighted by the areas occupied by the core and air gap?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
