How to find initial velocity given distance and angle
8 replies · 10K views
tsukuba
A projectile is fired with initial velocity Vo at an angle of 20° with the horizontal. Determine the required value of Vo if the projectile is to hit point b.
point b is 3 km away.
y=(Vy)o t + 1/2 a t^2
i tried isolating time(t) from the above formula which gave me square root of 2y/a but i can't take the square root of a negative number that bring the acceleration
Some hints: Draw the diagram and then use the formula. What do you know about the x-distance and y-distance?
Hi Tsukuba. Welcome to Physics Forums.
What is the value of y when the projectile reaches the ground again? What is the acceleration "a" in your equation for y? Can you use your equation for y to figure out how much time the projectile is in the air?
Chet
hello and thank you.
a=-9.81 m/s^2
I can use the equation because i would have 2 unknowns, that being the initial velocity and time. Like i said I tried isolating time and the formula i get is square root of 2x/a and i can't take the square root of a negative number.
a=-9.81 m/s^2
As I see it, your equation for the y direction is going to be:
[tex]0=v_0\sin(20)t-\frac{9.8}{2}t^2[/tex]
Is this in agreement with your assessment? If so, you can solve this equation for t by factoring the right hand side, and discarding the root at t = 0. In terms of v0, what do you get for t?
Chet
instead of the 0 wouldn't i have the distance of 3km?
here is the question and the diagram
We are talking about the y direction here, not the x direction. When the projectile hits the ground, y = 0.
