How to find the amount of inter record gap in a magnatic tape?
  • Thread starter Thread starter seini
    Gap
To determine the largest inter-record gap (IRG) that allows 80% of a 2400-foot magnetic tape to contain data, one must consider the tape's recording density of 6400 Bpi and the size of each data record, which is 100 bytes. The problem can be approached as a mathematical calculation, focusing on the given parameters to find the maximum allowable gap. The discussion highlights that the traditional format of magnetic tape typically has a fixed IRG, with the data record length being adjustable. Participants emphasize the need to work through the math step-by-step to arrive at the solution. Understanding these principles is essential for solving the tutorial question effectively.
seini
hello i have a question given to me on a tutorial which is to find what is the largest IRG that will allow 80 percent of the tape to be data in 2400 foot magnetic tape has recording density 6400 Bpi and data records are 100 bytes and memory buffer is 10,000. i have been looking every where but i did not find any luck ...can someone help me with this question please
Welcome to the PF.
What kind of information does the tutorial give you before asking this question? There must be some context and useful information in the tutorial to help you answer this question, right?
well it suppose to be a tutorial but our lecturer said to go and do some research on it and the information that was given is the one i post it and our text did cover magnetic tape and i have been searching in the internet for it but it seem it does not really give me information on how to find it...
I could be missing something, but it looks to be just a straight math problem. You are given the data density in Bytes per inch (is that what Bpi stands for?), and you are given the amount of data and the length of the tape. You want the data to end up being 80% of the tape, so how big can the gaps be?
Try just working it as a math problem using the numbers you are given. Show us your work, so we can see if it seems you are on the right path.
I think that's right, because this is back-to-front compared with how the format of real mag tape used to work. The inter-record gap was a fixed size, long enough (usually a few mm) to allow the tape to stop and start between records. The thing you could change was the data record (block) length, not the gap length.
10K
