How to Find the Balancing Mass and Supporting Tension in a Beam?
To find the balancing mass and supporting tension in a 1m long beam with a 5N weight, the forces and torques acting on the system were analyzed. The equations used included summing forces in the vertical direction and calculating torque about a pivot point. The initial calculations suggested a mass of 6.5kg and a tension of 8.45N, but the user recognized discrepancies in their force values leading to incorrect results. A request for clarification on the errors in the calculations was made, indicating the need for further assistance. Accurate calculations of forces and torques are crucial for determining the correct balancing mass and supporting tension.
Kingrick
for the 1m long, 5N beam below, find the balancing mass m and the supporting tension T
T
| m | |(25cm) | 2kg |
---------------------------------(1m)
f=ma
torque= Fxr
cross product, F x rsinx
first i summed the forces
Fx=0, no forces acting in x.
Fy=0
forces acting
1. m1g= 9.8m1
2> m2g= 19.6N
3. CG= 5n
4. T =?
9.8m1 + 19.6N + 5N - T= 0
so T = 9.8m1 + 24.6N
next I summed the torques
19.6N * 0.75m + 5 * 0.25 -(9.8)(.25m)m1 = 0
m1 = 6.5kg
Fm1= 63.7N
the actual answer of the force is -88.7N, and the T=8.45
seeing how i have the wrong force values i know that my T will be wrong using it. if anyone can show me where I went wrong in this one that would be very helpful thanks.
sorry about picture, i just uploaded a paint file so hopefuly that works.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
