How to find the height where two same marbles have the same velocity?
  • Thread starter Thread starter mwahx3
    Height Velocity
To find the height where two identical marbles have the same velocity, one dropped from Earth and the other from the Moon, it's essential to consider their differing gravitational accelerations (9.8 m/s² for Earth and 1.6 m/s² for the Moon). The problem implies that the marbles are released from the same height, but the velocities will differ upon impact due to gravity unless they reach terminal velocity. The marble on Earth will eventually reach terminal velocity due to air resistance, while the Moon marble will not experience air resistance. To solve the problem, calculate the terminal velocity of the marble on Earth and then determine the height from which the Moon marble must be dropped to reach that same terminal velocity upon impact. The terminal velocity of the Earth marble is the key value needed for the calculations.
mwahx3
How do you find the height where two same marbles have the same velocity when one marble is dropped from the Earths atmosphere (g=9.8) and the other is dropped from the Moons atmosphere (g=1.6)? Both are dropped from the same height
kinematic equations
I have absolutely no idea where to start...
Is that the question exactly?
yes.
mwahx3 said:
yes.
Are they saying the velocity is the same as they hit the ground?
That's a strange question... because if they are dropped from exactly the same height, then when they hit the ground they'll both always have different velocities because the g's are different... unless the height they are dropped from is 0...
yea that was what i was wondering...no it doesn't say that.
maybe the velocity is the same right when they are released?
the only possible reason i can think of...
Do they give any other numbers... like the height at which they're released?
no they dont. they just say at height 'H'.
Hmmm... that gives the impression that the answer can be given in terms of H... do they also say velocity V or anything like that?
no, since they ask for the velocity in one part of the problem...
Do they give drag or air resistance for this question?
F=-kv
and k= 0.1854
mwahx3 said:
F=-kv
and k= 0.1854
Ah... ok, now I think I understand... a marble is dropped from a height on earth... due to air resistance it reaches its terminal velocity before hitting the ground... when it hits its terminal velocity, the net force on it is 0... so its acceleration is 0 at that point... and it stays at that terminal velocity...
On the moon, there's no atmosphere... so there's no air resistance to think about.
So, first find the terminal velocity of the marble on earth... then find the height that the marble needs to be dropped from on the moon, so that it reaches that velocity just as it hits the ground.
ohh okay thank you. I think I got the terminal velocity...but I'm having trouble finding the height the marble needs to be dropped from the moon. What velocity should I use?
The terminal velocity that you get for the Earth marble.
ahhh okay! thank you! would that just be my answer?
Yeah, the terminal velocity would be your answer for that part.
