How to find the number that's evenly divisible by a set of numbers from 1 to n?
  • Thread starter Thread starter newb
    Numbers Set
To find the smallest number that is evenly divisible by all integers from 1 to n, the problem can be framed as calculating the least common multiple (LCM) of that range. The LCM can be derived using the formula LCM(a, b) = |a*b|/GCD(a, b), where GCD is easily computed using the Euclidean algorithm. For multiple numbers, the LCM can be found iteratively by calculating LCM of pairs, such as LCM(a, b), then LCM(LCM(a, b), c), and so on. While brute force methods can work for smaller n, they are inefficient for larger values like n=20. Utilizing the LCM and GCD approach is a more elegant and efficient solution.
newb
How can you go about finding the smallest number (x) that is evenly divisible by a set of numbers from 1 to n?
For example:
If n = 3, x=6
n = 4, x=12
n=5, x=60
n=6, x=60
This is easy to do when n is a small number, however how would one go about finding the answer if n=20 for example?
I have written a program that tries to brute force the answer, but I'm almost certain there's a much more elegant way to do it. Any advice?
Mathematics news on Phys.org
Here's the program I wrote by the way, incase anyone is interested:
Code:
class Problem5 {
 static int[] theArray;
static int multiplyer = 11 ;
 static boolean test= false;
static int current;
 //Makes array
 void maker (int number){
   for(int i=number; i>0; i--){
     theArray[i-1]=i;
  public static void main (String[] args){
   Problem5 instance1 = new Problem5();
   theArray = new int[multiplyer];
   instance1.maker(multiplyer);
   current = theArray[theArray.length-1];
   System.out.println (current);
   while (test == false){
     for(int i = theArray.length; i>0; i--){
     if (current % theArray[i-1]>0){
       current = current + theArray[multiplyer -1];
       i=0;
       test = false;
     } else{
       System.out.println(current+" is divisible by "+ theArray[i-1]);
       test = true;
Phrased another way, your problem is to find the lowest common multiple (LCM) of a set of numbers from 1,...,n . Luckily, there is an easy formula to get the LCM for two numbers a and b from the greatest common divisor (GCD): LCM(a,b) = |a*b|/GCD(a,b) . I say luckily because finding the GCD is easy - just use the Euclidean algorithm. There's probably a snazzy way to deal with this for more than two numbers but you could adopt it by finding LCM(a,b), then LCM(LCM(a,b),c), etc. Check out http://en.wikipedia.org/wiki/Least_common_multiple
If you stick with a brute force approach, remember that apart from {1}, each set contains 2. Think about what this means for the LCM...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
