How to Find the Phase Difference in Degrees
3 replies · 37K views · last reply
etotheo
Bit of a noob question,
I've measured the phase difference between sine waves of V(in) and V(out) using an oscilloscope to be 22.0 micro-seconds at a frequency of 10.4 kHz.
How would I find the phase difference in degrees?
Thanks.
Found a good link:
http://www.sengpielaudio.com/calculator-timedelayphase.htm"
The simplest way would be to measure the width of one cycle (if your scope gives you frequency, simply invert that) to give you the period. In your case, the frequency is given, so the period would be 1/10400 cycles per second = 96.15 micro-seconds per cycle.
On cycle equates to 360 degrees (that is, there are 360 degrees in one cycle). So, take your phase offset in time (22 micro-seconds), divide it by the period (96.15 micro-seconds per cycle) and multiply by 360 degrees per cycle. The result is the angular offset.
22 micro-seconds / 96.15 micro-seconds per cycle * 360 degrees/cycle = 82.37 degrees
Or, more simply, take the offset in time and multiply by the frequency. Then, multiply this result by 360 degrees per cycle.
22 micro-seconds * 10400 cycles per second * 360 degrees per cycle = 82.37 degrees
Just wanted to clean up my earlier post...
zgozvrm said:
The simplest way would be to measure the width of one cycle (if your scope gives you frequency, simply invert that) to give you the period. In your case, the frequency is given, so the period would be:
[tex]\frac{1}{10400}\enspace cycles\enspace per\enspace second = \frac{1\enspace cycle}{10400\enspace Sec}\approx\frac{96.15\mu{Sec}}{cycle}[/tex].
One cycle equates to [tex]360^\circ[/tex] (that is, there are [tex]360^\circ[/tex] in one cycle). So, take your phase offset in time [tex](22 \mu{S})[/tex],
divide it by the period [tex]\left(\frac{96.15 \mu{S}}{cycle}\right)[/tex] and multiply by [tex]\frac{360^\circ}{cycle}[/tex]. The result is the angular offset.
[tex]22 \mu{S}\div \frac{96.15 \mu{S}}{cycle} \times \frac{360^\circ}{cycle} \approx 82.37^\circ[/tex]
Then, multiply this result by [tex]\frac{360^\circ}{cycle}[/tex].
[tex]22 \mu{S} \times \frac{10400 \enspace cycles}{Sec} \times \frac{360^\circ}{cycle} \approx 82.37 ^\circ[/tex]
