How to find the velocity of a pendulum
  • Thread starter Thread starter grr_physics
    Pendulum Velocity
To find the velocity of a pendulum bob at a specific height, conservation of energy principles are applied, equating potential energy lost to kinetic energy gained. The user calculated the potential energy at the rest position as 5.91 J and the velocity there as 3.08 m/s. To determine the velocity at 0.250 m above the rest position, the vertical height change must be calculated using trigonometry based on the initial horizontal displacement of 1.80 m. The equation mgh = 1/2mv^2 is suggested for solving the problem, where g is the acceleration due to gravity. The discussion emphasizes using energy conservation and trigonometric calculations to find the desired velocity.
grr_physics
How to find the velocity of a pendulum...need help!
A 3.60 m long pendulum with a 1.25 kg bob is pulled sideways until it is displaced 1.80 m horizontally from its rest position. If the bob is released, calculate the speed of the bob when it is 0.250 m about it's rest position.
I found the potential energy when it passes through rest position= 5.91 J
and the velocity when it passes through rest position is 3.08 m/s. I don't know how to find it at 0.250 m & need help please!
Need help to find the velocity of a pendulum at a distance please!
1. Homework Statement
2. Homework Equations
I think you mean you found the kinetic energy when it passes throught the rest position this being equal to the loss of potential energy.Use the same method,find the vertical distance moved when the horizontal displacement goes from 1.8m to 0.25m and use PE lost=KE gained.
Welcome to PF!
Hi grr_physics! Welcome to PF! :wink:
grr_physics said:
I found the potential energy when it passes through rest position= 5.91 J and the velocity when it passes through rest position is 3.08 m/s.
You don't need to do that …
just use conservation of energy (and a bit of elementary trig). :smile:
so do i do this:
Ep = Ek
mgh = 1/2mv^2
gh = 1/2v^2
(9.81)(0.250)=1/2v^2
and keep going til i get the answer? where do i do trig?
so do i do this:
Ep = Ek
mgh = 1/2mv^2
gh = 1/2v^2
That's right.
And you'll need the trig to find the height when the horizontal displacement is 1.80 m :wink:
thanks! :)
Two threads merged into one. Please do not multiple post your questions, grr.
sorry, promise i won't anymore!
