How to find the volume of this pulley?
  • Thread starter Thread starter SagarPatil
    Pulley Volume
The discussion focuses on calculating the volume of a pulley using the area of a sector formula. Initial calculations yielded a volume of 6.27 cubic inches, but participants identified errors in area calculations and double-counting certain sections. The correct approach involves determining the area of both the large and small sectors while ensuring proper subtraction of overlapping areas. After several iterations, the revised total area calculation led to a volume of approximately 3.58 cubic inches. Accurate application of formulas and careful consideration of the geometry are crucial for arriving at the correct volume.
SagarPatil
The problem is asking to find the volume of this pulley
Formulas that is in the chapter.
Area = r^2*θ/(2)
Where θ is in radians
I drew the drawing in solid works and got the volume to come out to 6.27 cubic inch. But I am not sure if this is the correct answer.
I have no idea where to start. There is question in the chapter that is asking for the volume except this.
Area = r^2*θ/(2)
Volume is just Area * Thickness, correct? So start by finding the top area of the figure. It is composed of the pie-shaped arc and the cylinder, with part of each cut away.
Make a sketch of the top of the figure, and start adding and subtracting areas. Show us what you get... :smile:
Ok, makes sense
So,
Area of the sector = 5.270^2 * 0.97(rad) / 2 = 13.5
Area of the big circle = 1.23
Area of small circle = 0.2
I subtract 0.2 so it comes out to 14.53
14.53 * 0.250 = 3.63 cubic inch.
SagarPatil said:
Ok, makes sense
So,
Careful -- it looks like you may be double-counting a small piece of area. Do you see where it is?
Also, it's a good idea to carry units along in your calculations. A number without units can be a problem... :smile:
I don't see where I did wrong. I did it a couple of times and got the same answer.
SagarPatil said:
Ok, makes sense
So,
Your area for the sector is wrong, and as berkeman said, you're counting part of the area twice. You're calling the radius of the sector 5.270". You need to subtract off the part of the sector that is in the circular portion.
If you do the same sequence of steps, but they aren't the right steps, you won't get the right answer. If you're careful, you'll get the same wrong answer twice.
Ok I understand that i am counting it twice
If I subtract 13.5-1.23-0.2 = 12.07 this gives me the area of the sector
So now
12.07 + 1.23 - 0.2 = 13.1 is the total area
13.1*0.250 = 3.275 cubic inch
is the answer correct ?
So now
Remember, subtracting the area of the hub, 1.23 in2, from the area of the sector, 13.5 in2, automatically includes the area of the hole, 0.20 in2. Subtracting 0.20 in2 for the hole again is incorrect.
Hello, I got it.
You so here is what I did
Area of the Big sector = 5.270^2 * 0.97(rad) / 2 = 13.5
Area of Small Sector = 0.625^2 * 0.97(rad) / 2 = 0.189
So,
13.5+1.23-0.2-0.189 = 14.341
14.341 * 0.250 = 3.58 in^3
Likes berkeman
Fix your formula for area.
Do you want to elaborate on which formula Sagar wrote? He is showing four area calculations.
There is no division by 2.
Are you saying that the OP didn't divide by 2 or are you saying that the formula for the area of a sector shouldn't have a divisor of 2? If you are saying the latter, then you're mistaken. The area of a sector of a circle of radius r, where the sector subtends an arc of ##\theta## radians, is ##A = \frac 1 2 r^2 \theta##.
Likes theodoros.mihos
