How to Identify HOMO and LUMO in an Sn2 Reaction?
The discussion revolves around identifying the Highest Occupied Molecular Orbital (HOMO) and Lowest Unoccupied Molecular Orbital (LUMO) in the context of an SN2 reaction, focusing on the role of a thiolate nucleophile and the orbital interactions involved. Participants explore the theoretical aspects of molecular orbitals, stereochemistry, and the reaction mechanism.
  • Some participants assume the reaction is an SN2 type due to the presence of a polar aprotic solvent and a strong nucleophile.
  • There is confusion regarding the attack position of the thiolate (SEt-) and how to represent the reaction mechanism, as both steps occur simultaneously.
  • Participants discuss the identification of the HOMO and LUMO, with some suggesting that the orbital around sulfur is the HOMO and that around carbon is the LUMO.
  • One participant proposes that the orbital diagram should focus on bonding, non-bonding, or antibonding characteristics rather than hybridization.
  • Questions arise about the electron count in the thiolate orbital, with a suggestion that it contains a lone pair of two electrons.
  • There is a discussion about the energy levels of bonding and antibonding orbitals, with some participants correcting earlier assumptions about their relative energies.
  • One participant emphasizes the importance of drawing Lewis structures to clarify electron counts and charges.
  • The interaction between the thiolate and the carbon is described as forming a new molecular orbital that has bonding character with sulfur and antibonding character with bromine.
Participants express uncertainty regarding the specifics of orbital interactions and the representation of the reaction mechanism. Multiple competing views on how to approach the orbital diagram and the nature of the HOMO and LUMO remain unresolved.
Limitations include unclear instructions in the original question, assumptions about the nature of the orbitals involved, and the need for further clarification on electron counts and orbital energies.
Yokoko
Question as attached to this thread. I'd like confirmation whether or not my solution to a) is correct. But I am mainly confused with b)
The equation can be seen in the picture. I was assuming it was an Sn2 reaction given the polar aprotic solvent and strong nucleophile.
For b), I assumed that the question asked me to draw the orbitals as shown above (as opposed to orbital diagram) because it asked me to identify the HOMO and LUMO.
I'm confused as to where SEt (-) attacks/how to draw the attack i.e. the reaction itself as both steps occur at the same time. Also I'm assuming that the orbital around S is the HOMO and the orbital around C the LUMO. Is that correct?
Thanks a lot!
Yes.
Honestly, it’s probably best to do both.
Well, you got the stereochemistry inversion correct, so where do you think the thiolate attacks?
It’s probably more useful to only draw the portions of the orbitals that are important for the changes that occur during the reaction.
It’s kind of tough to give you more help without seeing you put in some more effort first.
Thanks for your input!
I know it's not a lot but I started working upon your prompts. In the first one is the orbital attacking the C centre with the positive charge after Br has left. Maybe it would be good to but Br- on the side too?
The second one is my attempt at the orbital diagram. Again, I'm not sure how this question wants me to answer this. This one shows the c centre bonding to a hydrogen and another sp3 hybridised C (again unsure how to draw in the second one as both methyl and ethyl are bonded by a sp3 hybridised C, right? Are they all of equal energy?), The one orbital bonding with SEt is missing too as of now...
Thanks again
Yokoko said:
after Br has left.
It’s SN2. Should Br have left?
I agree, the question isn’t particularly clear. I’ll try to focus on the most important conceptual takeaways. Instead of focusing on the hybridization of the orbitals, it’s probably better to focus on whether the interacting orbitals are bonding, non-bonding, or antibonding. Bring those ideas into your answer and see what you can come up with.
I think I've come a bit farther this time. The bonding/anti bonding hint really helped! :)
Two questions: is there only one or two e- in the orbital of SEt- ? It is a lone pair, so there would be 2 e-, correct?
And would the orbital diagram drawn enough to answer the question combined with the sketch?
Thanks again!
Getting closer. Look at the MO diagram in your second picture. Is the sigma antibonding orbital higher or lower in energy than the sigma bonding orbital?
Also, a Lewis structure should give you an idea of whether the thiolate anion has a lone pair or an unpaired electron.
Oh you are right, the C would be lower in energy, therefore under the SEt orbital.
And since the bond with sodium breaks, it seems like it only has an unpaired electron left
I meant the MOs that are formed by the interaction of the sulfur with the carbon. You have the antibonding orbital lower in energy than the bonding orbital in your picture.
Look closer. The S has a negative charge. It really might help to draw out the Lewis dot structure and actually count the electrons around the sulfur.
So, this should be right now. I forgot about the negative charge on the sulfur, I think that was my mistake.
Better. I might have confused you before: the occupied sulfur HOMO is definitely lower in energy than the C LUMO. Otherwise it would be energetically favorable simply to transfer electrons to the lower energy empty orbital than to form a new set of MOs.
The biggest conceptual takeaway is this: the orbital that’s being created by the interaction of the thiolate with the carbon centered nucleofuge is a combination of the lone pair sulfur orbital and the C-Br antibonding orbital. The “bonding” orbital that ends up being formed by this combination has strong bonding character with the sulfur and strong antibonding character with the bromine. This is ultimately the reason that the C-Br bond breaks and the C-S bond forms.
That makes sense! Thank you so much for help, I know it took a while!
  • · Replies 28 ·
