How to increase oxidation in something
  • Thread starter Thread starter TheQuietOne
    increase Oxidation
Increasing the rate of oxidation in an object involves enhancing the speed at which it loses electrons, which can vary significantly depending on the type of object in question. The discussion highlights that "rate of oxidation" can refer to different processes, such as the combustion of wood, fuel consumption in engines, or metabolic reactions in living organisms. The ambiguity of the original question makes it challenging to provide a specific answer. To increase oxidation, one suggestion includes immersing the object in pure oxygen and applying heat, although caution is advised due to potential hazards, such as the risk of explosion when using lasers on oxygen tanks. Overall, a clearer definition of the object and context is crucial for a more precise discussion on increasing oxidation.
TheQuietOne
Not sure if this is Chemistry or not, but how would one increase oxidation in an object?
Chemistry news on Phys.org
Define "increase oxidation in an object". As worded this statement doesn't make sense.
Sorry, I meant increase the rate of oxidation in an object.
Increasing the oxidation state means that it would need to continue losing electrons. How to do that depends upon the "object" that you are wondering about, as there various oxidants that can be used. Can you be more specific?
I am afraid it still absurdly ambiguous.
"Rate of oxidation in an object" can be the speed at which wood is burnt in my fireplace, speed at which the fuel is consumed in a car engine, the speed at which battery works, or the speed at which I am burning glucose when riding on a bike (plus some).
Do you see why it is not possible to even try to answer your question?
Likes Bystander
Going through some terminology here may be of assistance for you. The term oxidation already implies a change by its very definition, so your question does carry a sort of roundabout meaning. I did still attempt to understand what you are trying to ask though. This term is probably best used in the context of atoms or molecules (not macroscopic objects).
https://en.wikipedia.org/wiki/Redox
Immerse your object into (as best as can be achieved), 100% pure Oxygen?.
Maybe then heat it up with lasers?
Yes! thank you rootone! ( sorry about my lack of chemistry knowledg to y'all)
...careful not to heat an oxygen tank up with a laser, it could explode.
