How to know phase difference will be of a light wave entering a thin film?
When a light wave enters a thin film, the phase difference depends on the indices of refraction of the two media. A wave reflecting off a boundary where the second medium has a higher index of refraction experiences a 180-degree phase shift, while a wave reflecting off a boundary where the second medium has a lower index does not. Specifically, when light transitions from air (n = 1) to water (n = 1.33), the wave reflecting off the air-water boundary undergoes a phase shift, while the wave reflecting off the bottom of the film does not. Therefore, the net phase difference when light exits the thin film is determined by these interactions at both boundaries. Understanding these principles is crucial for analyzing light behavior in thin films.
fairtrade55
For instance, I know if a light wave traveling air (n = 1) enters a thin film of water (n = 1.33), there will be a phase difference.
My textbook sol'n manual states that there will be a 180 degree phase difference for a wave of light that reflects of the top of the air-water boundary, but NO phase difference for a wave that refracts into the thin layer of water and reflects off the bottom of the thin layer.
But the book fails to explain why and how we are supposed to know when a phase difference occurs at the two boundaries, and WHAT the phase difference will be at the two boundaries, and what the net phase difference is. Can anyone help?
Science news on Phys.org
Never mind I found the answer. If anyone in the future comes looking for the answer to this:
If light goes from a ---> b with n(a) > n(b), the reflected wave has no phase shift
If light goes from a ---> b with n(b) > n(a), the reflected wave has half cycle (180 deg) phase shift
n above is index of refraction. b is the inside of the thin film.
Entering the thin film, most probably nb > na, so 180 deg phase shift.
So at the back of the film (exiting it), the light will probably be going from higher n to lower n, so there's no phase shift
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
