How to Linearize a Function without Using Logarithms
The discussion revolves around the linearization of the function y = αx e^(βx). Participants explore methods to achieve this without using logarithms, considering alternative approaches such as series expansions.
  • Participants discuss the use of logarithms for linearization but encounter complications with multiple terms involving x. Some suggest using a Maclaurin series expansion to simplify the function, while others question the linearity of the resulting expressions.
The conversation includes various interpretations of how to linearize the function, with some participants proposing the use of series expansions and others focusing on logarithmic transformations. There is no explicit consensus, but several productive lines of reasoning have been presented.
Participants note the challenge of fitting the transformed equations into a standard linear format, raising questions about the dependency of variables in the context of linear regression.
mrwest09
Linearize the following model:
y=[tex]\alpha*x*e^{\beta*x}[/tex]
The only relevant equations I can think of are the laws of natural logarithms.
I have tried to taking the ln of both sides however that leaves me with an equation that has two term with x in it.
ln(y)=ln(a)+ln(x)+Bx
I'm sure there has to be a simple solution but I can't visualize anything without running into the same problems.
It's possible that you're supposed to do this using a Maclaurin series representation for your function, and discard the x2 and higher degree terms.
The Maclaurin series for e[itex]\beta[/itex]x is
[tex]e^{\beta x} = 1 + \frac{\beta x}{1!} + \frac{(\beta x)^2}{2!} + ... + \frac{(\beta x)^n}{n!} + ...[/tex]
Multiply the terms in this series by [itex]\alpha[/itex]x and then discard all terms in x2 or higher.
EDIT:
On second thought, there's a simpler formula that is related to the above.
If x is "close to" 0, then f(x) [itex]\approx[/itex] f(0) + x*f'(0). This gives you a first degree polynomial approximation to your function.
Correct:
[tex] \ln{y} = \ln{\alpha} + \ln{x} + \beta \, x[/tex]
So, [itex]\ln{y} - ln{x}[/itex] is a linear model relative to the function [itex]x[/itex] and you can use linear least squares fit to extract the value of the coefficients [itex]\ln{\alpha}[/itex] (the intercept) and [itex]\beta[/itex] (the slope).
Okay that makes some sense but if you were to fit that into your standard y=mx+b format for linear lines wouldn't your 'y' value depend on two variables? In this case wouldn't it not be linear?
This is how I am picturing the final equation:
[tex] <br /> \ln{y} - \ln{x} = \beta \, x + \ln{\alpha}<br /> [/tex]
y = m x + b
Yes. In:
[tex] \tilde{y} = m \tilde{x} + b[/tex]
we need to calculate:
[tex] \tilde{y} = \ln{y} - \ln{x}[/tex]
[tex] \tilde{x} = x[/tex]
and then:
[tex] m = \beta, \; b = \ln{\alpha}[/tex]
