B Measuring Rest Length While Moving
phyti
I don't remember seeing this solution to the question.
Imagine an object of length d with a reflector on the far end (x=4).
A moves past the object at speed a, emitting a signal at the origin in the positive x direction. A makes one pass in the +x direction, reverses and makes one pass in the -x direction.
Relative to U, with c=1, a=.4:
time out is the same for both passes, t0=d/c.
return time-pass 1, t1=t0(1-a)/(1+a)
return time-pass 2, t2=t0(1+a)/(1-a)
with time dilation for A;
total time-pass 1, T1=2t0*sqrt ((1-a)/(1+a))
total time-pass 2, T2=2t0*sqrt ((1+a)/(1-a))
t0=.5sqrt(T1*T2)
Example:
d=.5sqrt(5.24*12.16) = 4.0
Looks right, but the methodology seems overly complex to me. I am required to decelerate from +a to -a. Why not just stop at zero and measure in the rest frame? Or just use the Lorentz transforms, given that I need to know the velocity precisely enough to sign flip it?
I agree with simplicity. Was just making calculations for doppler effects, and thought this would work, but needed another opinion.
Thanks.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
