How to phrase a hypothesis for simulated model on a experiment report?
To formulate a hypothesis for a simulation experiment, it is essential to clearly state that the model is a simplified representation and not reflective of real-life complexities. A suitable hypothesis could be, "If A is increased, then B will increase, under the assumption that no other attributes influence B in this simulation." It is important to emphasize the controlled nature of the simulation, allowing only one variable to change while others remain constant. The discussion highlights the need for clarity in communicating the limitations of the model. Overall, the focus is on accurately framing the hypothesis while acknowledging the model's constraints.
Eng Student 357
I'm setting up an experiment for a simulation. I'm not sure how to formulate the hypothesis. The model used in the simulation is the first iteration, so I'm just using 2 attributes, 1 independent (A) and 1 dependent (B). As a result, I need to state explicitly that this model is not representative of real life, and just used as step in extending the model. In real life there are many other factors which we could assume are included, but I'm not simulating these yet.
So my question is, how do I state this explicitly (and formally) as part of my hypothesis?
2. Homework Equations
My initial thought is to state the hypothesis as:
If A is increased, then B will increase.​
With assumptions made:
If A is increased, then B will increase, assuming for the purpose of the simulation no other attributes affect B.​
Welcome to PF;
... you just did: say that.
... you don't need the assumption - you are simulating the results of an experiment where there is strict control of variables, so only one will be allowed to vary and the other measured.
The description is very abstract though - is there some reason you cannot tell us what you are simulating?
Thank you, Simon. That's helpful. Glad I was on the right track.
I wanted to keep it general. It has to do with factors affecting human behaviors in a civic context.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
