How to prove Bayes' rule for probability measures?
  • Context: Graduate
  • Thread starter Thread starter winterfors
    Probability
The discussion revolves around the proof of Bayes' rule for probability measures, particularly in the context of measure theory. Participants explore the formulation of Bayes' rule in terms of probability measures and the challenges associated with proving it, as well as the relationship between conditional probability measures and joint probability measures.
  • One participant proposes a measure-theoretic generalization of Bayes' rule involving Radon–Nikodym derivatives and conditional probability measures.
  • Another participant suggests a proof based on a filtration of increasing sigma algebras, but notes it may not align with the original inquiry.
  • Some participants express uncertainty about how to define the mapping of probability measures and the implications for the proof of Bayes' rule.
  • There are discussions about the conditions under which Radon-Nikodym derivatives can be applied, with some participants questioning the validity of certain definitions and assumptions.
  • One participant highlights the need for a reformulation of Bayes' rule using probability measures instead of densities, indicating a desire to clarify the application of the Law of Total Probabilities in this context.
  • Concerns are raised regarding the integration over different measurable spaces and the implications for defining joint probability measures.
  • A request for a simple example to illustrate the theorem is made, indicating a need for concrete calculations to clarify the discussion.
Participants do not appear to reach a consensus on the proof of Bayes' rule for probability measures. Multiple competing views and uncertainties remain regarding the definitions and applications of the concepts involved.
Limitations include unresolved definitions of probability measures, the applicability of Radon-Nikodym derivatives, and the integration over different measurable spaces, which complicate the proof process.
winterfors
Consider a probability space [itex](\Theta, \Sigma_\Theta, P_\Theta)[/itex], where [itex]P_\Theta[/itex] is a probability measure on the sigma-algebra [itex]\Sigma_\Theta[/itex].
Each element [itex]x \in \Theta[/itex] maps onto another probability measure [itex]P_{\Omega | x}[/itex], on a sigma-algebra [itex]\Sigma_\Omega[/itex] on another space [itex]\Omega[/itex].
In this situation, one should (as far as I can see) be able to write write a measure-theoretic generalization of Bayes' rule
[tex]{P_{\Theta |y}}(A) = \int\limits_{x \in A} {\frac{{d{P_{\Omega |x}}}}{{d{P_\Omega }}}(y)d{P_\Theta }}[/tex]
for any [itex]A \subseteq \Theta[/itex], given an observation [itex]y \in \Omega[/itex] where
[tex]{P_\Omega } = \int\limits_{x \in \Theta } {{P_{\Omega |x}}d{P_\Theta }}[/tex]
and [itex]{d{P_{\Omega |x}}/d{P_\Omega }}[/itex] is the Radon–Nikodym derivative of [itex]P_{\Omega |x}[/itex] with respect to [itex]P_{\Omega}[/itex].
The problem is that I cannot see how to prove it (I;m sure the proof is fairly simple). Anyone wants to help?
SW VandeCarr said:
This proof may or may not be what you are looking for. It's based on a filtration: [itex]F_1, F_2, ...,F_{N-1}, F_N[/itex] as an increasing sequence of sigma algebras.
http://01law.wordpress.com/2011/04/09/bayes-rule-and-forward-measure/
As far as I can see, it's not quite what I'm looking for. What I'm trying to do above is to reformulate Bayes' rule for probability densities, usually expressed
[tex]p(x|y) = \frac{{p(y|x)}}{{p(y)}}p(x)[/tex]
which follows trivially from the definition of a joint probability density [itex]p(x,y) = p(y|x) p(x)[/itex]. But for probability measures, it gets slightly more tricky...
The rule for probability densities follows from Bayes' Rule and the Law of Total Probabilities:
[itex]f_X(x|Y=y) = \frac{f_{X,Y}(x,y)}{f_Y(y)} = \frac{f_Y(y|X=x)\,f_X(x)}{f_Y(y)} = \frac{f_Y(y|X=x)\,f_X(x)}{\int_{-\infty}^{\infty} f_Y(y|X=\xi )\,f_X(\xi )\,d\xi }\![/itex].
Do you want to reformulate this?
EDIT: Any reformulation will need to take into account that the application of Bayes' Rule must be expressed as a posterior probability which is defined in terms of a probability space and the Law of Total Probabilities.
What is this mapping? How exactly is [itex]P_{\Omega | x}[/itex] defined?
I only meant that for every [itex]x \in \Theta[/itex] there is one probability measure [itex]P_{\Omega | x}[/itex] on [itex]\Sigma_\Omega[/itex] over the space [itex]\Omega[/itex]. The probaility measures [itex]P_{\Omega | x}[/itex] are thus consitional on [itex]x[/itex].
This allows us to define a joint probability measure on the (Cartesian) product space [itex](\Theta \times \Omega ,{\Sigma _\Theta } \times {\Sigma _\Omega })[/itex]
[tex]{P_{\Theta \times \Omega }}(C) \equiv \int\limits_{x\in A} {{P_{\Omega |x}}({B_x})d{P_\Theta }}[/tex] for any [itex]C \in {\Sigma _\Theta } \times {\Sigma _\Omega }[/itex], where [itex]A \in {\Sigma _\Theta }[/itex] and [itex]{B_x} \in {\Sigma _\Omega }[/itex] are defined as [itex]A = \{ x:(x,y) \in C\}[/itex] and [itex]{B_x} = \{ y:(x,y) \in C\}[/itex].If one could prove that [tex]{P_{\Omega |x}} = \frac{{d{P_{\Theta \times \Omega }}}}{{d{P_\Theta }}}(x)[/tex] where [itex]d{P_{\Theta \times \Omega }}/d{P_\Theta }[/itex] is the Radon–Nikodym derivative of [itex]{P_{\Theta \times \Omega }}[/itex] with respect to [itex]{P_\Theta }[/itex], then the theorem above (that I want to prove), i.e.
[tex]{P_{\Theta |y}}(A) = \int\limits_{x\in A} {\frac{{d{P_{\Omega |x}}}}{{d{P_\Omega }}}(y)d{P_\Theta }}[/tex] would follow by symmetry, but I'm not sure of how to do that...
Perhaps I've misunderstood you, but... [itex]f[/itex] would be a Radon-Nikodym derivative if
[tex] P_{\Theta\times\Omega}(A) = \int_A f \, dP_\Theta[/tex] for all [itex]A \in \Sigma_\Theta\times\Sigma_\Omega[/itex] (product sigma-field). However this doesn't make any sense, because you have different measurable spaces on the left and right hand sides. Actually, the right hand side does not mean anything.
In the equation you refer to, the integration is not over a subset [itex]A \in \Sigma_\Theta\times\Sigma_\Omega[/itex] but over a subset of [itex]\Theta[/itex].
I was just quoting your definition of [itex]P_{\Theta\times\Omega}[/itex]. Later in you question you refer to [itex]\frac{dP_{\Theta\times\Omega}}{dP_\Omega}[/itex] as a Radon-Nikodym derivative, but this, as I tried to point out in my previous reply, doesn't make sense.
Yeah, I meant that [itex]{dP_{\Theta\times\Omega}}/{dP_\Omega}[/itex] would not be a function [itex]\Theta\rightarrow[0,\infty)[/itex], but a function [itex]\Theta\rightarrow\Gamma[/itex], where [itex]\Gamma[/itex] is a set of probaility measures on [itex]\Sigma_\Omega[/itex]. It might be a bit of a strech to call it a Radon-Nikodym derivative...
Yes, reformulating this using probaility measures instead of probability densities would allow me to prove what I want.
Hmm.. you denote by [itex]P_{\Omega | x}[/itex] just some arbitarily chosen probability measure on [itex](\Omega, \Sigma_\Omega)[/itex], i.e. you have a family of measures parametrized by [itex]x \in \Theta[/itex]. Then you define
To answer the question, whether
[tex]{P_{\Omega |x}} = \frac{{d{P_{\Theta \times \Omega }}}}{{d{P_\Theta }}}(x)[/tex], where the RHS is not a Radon-Nikodym derivative, you need to define the RHS, i.e. it cannot be just some function [itex]\Theta \to \Gamma[/itex]. Also you can't define it using the same equation you used for definition of [itex]P_{\Theta\times\Omega}[/itex]. A theorem would show that two separately defined things are equal, but I see only one defined object.
I sort of understand what you are trying to do, but not quite. Can you give a simple example of calculations with concrete values/sets of what the theorem would look like? E.g. in discrete case?
