How to select passive antenna for 2.4GHz system
  • Thread starter Thread starter rafik
    Antenna System
The discussion revolves around selecting a passive 50 Ohm surface mount chip antenna for a 2.4GHz WiFi system, focusing on the compatibility of antenna size and specifications with the WiFi module. Participants explore the critical parameters necessary for effective antenna selection.
  • Technical explanation, Debate/contested
  • One participant inquires if any 50 Ohm chip antenna can be used, suggesting a general approach to antenna selection.
  • Another participant emphasizes that the antenna size must correspond to the wave frequency, indicating potential issues with reception if the size is not appropriate.
  • A participant specifies the footprint of their PCB and mentions a specific antenna model (2450AT18B100E), seeking opinions on its suitability for a WiFi module.
  • Concerns are raised about the unknown implications of the antenna specifications, with a focus on wave resonant frequency and impedance matching as critical parameters for selection.
Participants express differing views on the criteria for selecting antennas, particularly regarding the importance of size and specific parameters, indicating that multiple competing views remain in the discussion.
Limitations include the lack of consensus on the specific parameters that determine antenna performance and the implications of the chosen specifications on overall functionality.
rafik
Hi, I need to select a passive 50 Ohm surface mount chip Antenna (size 3.2x1.6x1.2 mm) for my WiFi radio. Can I use any 50 Ohm chip Antenna available?
What do you mean by any? Antenna size should match wave frequency. Too big or to small and expect problems with reception.
Hi zoki85, the footprint on my PCB is 3.2x1.6x1.2mm, antenna will have to fit into the footprint space. I am looking at the following antenna for my WiFi module:
2450AT18B100E (2450 MHz 50 Ohm Antenna). In your opinion, will this antenna work well in a WiFi module? What are the critical parameters in selecting RF antenna in general?
Thank you.
I don't know will it work well (meaning of these numbers is unknown to me). Wave resonant frequency and impedance matching to auxilary circuit are the most important parameters.
Thank you zoki85
  • · Replies 37 ·
  • · Replies 17 ·
  • · Replies 37 ·
