How to show something transforms as a covector?
  • Thread starter Thread starter Baggio
Baggio
Considering a boost in the x direction, how do you show that
(d/dx,d/dy,d/dz,d/dt)
thanks
I assume you mean partial derivs.
Use the calculus rule relating \partial_x' to \partial_x.
thanks
I don't see that this is a covariant vector. If it was the -gradient then I'd see that (you used total derivatives rather than partial derivative. I've never seen such an object). If it was then I'd use the chain rule for partial differentiation.
Pete
yes sorry they are partials... why is the chain rule used.. I don't see how that leads to the solution
thanks
thanks
\frac{\partial}{\partial x'} = \frac{\partial x}{\partial x'}\frac{\partial}{\partial x} + \frac{\partial y}{\partial y'}\frac{\partial}{\partial y} + \frac{\partial z}{\partial z'}\frac{\partial}{\partial z} + \frac{\partial t}{\partial t'}\frac{\partial}{\partial t}
Now change coordinates (x, y, z, t) - > (x1, x2, x3, x4)
Then the above sum can be written as a sum which is identical to the law of covariant transformation.
Pete
I started reading a National Geographic article related to the Big Bang. It starts these statements: Gazing up at the stars at night, it’s easy to imagine that space goes on forever. But cosmologists know that the universe actually has limits. First, their best models indicate that space and time had a beginning, a subatomic point called a singularity. This point of intense heat and density rapidly ballooned outward. My first reaction was that this is a layman's approximation to...
Thread 'Dirac's integral for the energy-momentum of the gravitational field'
See Dirac's brief treatment of the energy-momentum pseudo-tensor in the attached picture. Dirac is presumably integrating eq. (31.2) over the 4D "hypercylinder" defined by ##T_1 \le x^0 \le T_2## and ##\mathbf{|x|} \le R##, where ##R## is sufficiently large to include all the matter-energy fields in the system. Then \begin{align} 0 &= \int_V \left[ ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g}\, \right]_{,\nu} d^4 x = \int_{\partial V} ({t_\mu}^\nu + T_\mu^\nu)\sqrt{-g} \, dS_\nu \nonumber\\ &= \left(...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
