How to solve a double incognite equation?
  • Thread starter Thread starter KRiBaH
To solve a double incognite equation with only one equation, you can express one variable in terms of the other. For example, from the equation 3x - 4y + 2 = 2(x + 1), you can isolate x or y. This results in an infinite number of solutions represented as points on a straight line in a coordinate system. Each point on this line corresponds to a valid (x, y) pair, indicating that either variable can take any value while the other is determined. Thus, without additional information, you cannot find exact values for x and y, only their relationship.
KRiBaH
Hello! I am new here! And i really like this site! So here's is my problem:
Well i know how to solve a simple equation with 2 incognites like:
x+y=2
x+4=2y
So in this case i do a substitue y=x-2 and use it in the second equation and it would be like:
x+4=2(x-2)
But the problem is if they only give me one equation with 2 incognites how can i solve it?
Example:
3x-4y+2=2(x+1)
Thanks!
If all you are given is one equation in two unknowns - like your example
3x-4y+2=2(x+1)
and no other information, then you have only two choices
1. Solve for x in terms of y: x = material involving only y and constants
2. Solve for y in terms of x: y = material involving only x and constants
Typically version 2 is selected, as we are accustomed to seeing equations with y isolated.
What is the setting for this question?
A single equation in two unknown numbers, x and y, has an infinite number of (x,y) solutions: The graph of something like 3x-4y+2=2(x+1) on an xy- coordinate system would be a straight line. Every point on the line gives an (x,y) pair that satifies the equation.
So that means that x or y can't have an exact number because it can be any number, like it can't be x=2, it must be like x € (-infinite,infinite) like the inequations is that what you mean?
Either x or y can be any number. Once one of them is chosen, the other is fixed.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
