How to solve for x? tricky algebra equation
  • Context: High School
  • Thread starter Thread starter Fuz
    Algebra
The discussion revolves around solving the cubic equation x3 - x2 + x - 2 = 0. Participants explore various methods for finding the roots of this polynomial, including factoring, the Rational Root Theorem, and numerical methods like Newton's Method. The conversation includes insights from high school and college-level algebra perspectives.
  • Some participants suggest factoring the polynomial or testing potential rational roots using the Rational Root Theorem.
  • Others point out that the equation may not be easily factorable and recommend numerical methods, such as Newton's Method, for finding roots.
  • A participant mentions that knowing the product of two numbers is 2 does not provide useful information for solving the equation.
  • There is a suggestion to simplify the problem by altering the equation to make it more amenable to factorization.
  • One participant discusses the complexity of the cubic formula and its historical context, indicating that it may not be necessary for this specific problem.
  • Concerns are raised about the appropriateness of course placement in high school mathematics, particularly regarding the readiness for such problems.
  • Some participants emphasize the importance of graphing to aid in understanding the behavior of the polynomial function.
Participants express a range of methods and approaches, indicating that there is no consensus on a single solution method. Multiple competing views on how to tackle the problem remain present throughout the discussion.
Some participants note the difficulty of the problem and the potential for confusion when dealing with polynomials of degree higher than 2. The discussion reflects varying levels of familiarity with algebraic techniques and the implications of course selection in high school curricula.
Fuz
How do you go about solving equations for x that look something like this:
x3 - x2 + x - 2 = 0
I'm stumped when I get to:
x(x2 - x + 1) = 2
All insights appreciated! :)
Mathematics news on Phys.org
What kind or level of Algebra? Are you studying College Algebra?
Try to factor the original polynomial. Can you divide it by (x-1), or (x+1), or (x-2), or (x+2)? Do any of those quotients have no remainder? If you can factor the polynomial in this way, then you may have something in the form, (x-a)(x-b)(x-c)=0, in which you can easily identify the solutions.
I'm actually just taking high school level AP Calc AB, but I was curious how you would solve equations like this one.
x3 - x2 + x - 2 = 0
x(x2 - x + 1) = 2
This doesn't do you any good at all. Knowing that the product of two numbers is 2 doesn't give you any knowledge about the two numbers, since there are infinitely many pairs of numbers whose product is 2.
What does do some good is getting a product of factors on one side of the equation, and 0 on the other. If two numbers multiply to zero, then one of the numbers has to be zero.
What can sometimes help is the Rational Root Theorem. Do a search on wikipedia to find out what that is. I tried all four possibilities for your polynomial and none of them worked. There are some formulas for solving cubics, but they're pretty complicated.
If all else fails, there are approximation techniques for finding the roots of a polynomial. One such method is Newton's Method, and there are several others.
Newton's Method is useless without a graph.
this may be a difficulty with course selection and placement in high school curricula:
The high school should not simply let you skip Mathematical Analysis or Precalculus. Fortunately when you get to college, you will take either Precalculus or College Algebra, in which you will study various topics about polynomial functions.
I've taken 3 years of algebra, and took pre-calculus last year. I've just forgotten how to do the problem.
As others have already pointed out, that equation is a difficult one as it doesn't factorize.
Why don't you try an easier one. Say if I change your equation slightly so that it's amenable to factorization. Can you solve this equation?
x3 - x2 - x - 2 = 0
Fuz,
I can tell you this about your equation as a function: It has no minimum and no maximum, and it has only one Real zero. Wondering how I know? Graphing calculator.
Either not factorable or not easily factorable.
x3 - x2 + x - 2 = 0
x(x2 - x + 1) = 2
You can focus on x2 - x + 1 to see an approach
you probably know
(x-1)2 = x2 - x - x + 1 = x2 - 2*x + 1
So, what added to itself would equal 1 instead of 2 to make x2 - x + C and how would you get it there. If you find out how to do this, you can figure out the rest.
x3 - x2 + x - 2 = 0
x(x2 - x + 1) = 2
You should start from the "rational root" theorem: any rational number root of the polynomial equation, [itex]a_nx^n+ a_{n-1}x^{n-1}+ \cdot\cdot\cdot+ a_1x+ a_0= 0[/itex] must be of the form [itex]\frac{m}{n}[/itex] where m evenly divides the constant term [itex]a_0[/itex] and n evenly divides the leading coefficient, [itex]a_n[/itex]. In this problem, the constant term is -2 which has divisors [itex]\pm 1[/itex] and [itex]\pm 2[/itex]. The leading coefficient is 1 which has divisors [itex]\pm 1[/itex]. That is, the only possible rational roots are [itex]\pm 1[/itex] and [itex]\pm 2[/itex]. It easy to see that none of those four possibilities does, in fact, satisfy the equation so it has no rational roots.
There is, however, "cubic formula, published by Cardano in 1545.
Note that
[tex](a- b)^3= a^2- 3a^2b+ 3ab^2- b^3[/tex]
and
[tex]3ab(a- b)= 3a^2b- 3ab^3[/tex]
Adding those [itex](a- b)^3+ 3ab(a- b)= a^3- b^3[/itex]
If we let x= a- b, m= 3ab, and [itex]n= a^2- b^3[/itex], we see that x= a- b satisfies the "reduced" cubic equation [itex]x^4+ mx= n[/itex] ("reduced" because there is no "[itex]x^2[/itex]" term).
The question is, "Suppose we know m and n. Can we recover a and b and so find x= a- b?" The answer is "Yes, we can!"
From m= 3ab, we have b= m/3a. Putting that into [itex]a^3-b^3= n[/itex], [itex]a^3- m^3/(3^3a^3)= n[/itex]. Multiply through by a^3 and we have [itex](a^3)^2- (m/3)^3= na^3[/itex] or [itex](a^3)^2- n a^3- (m/3)^3= 0[/itex], a quadratic equation in [itex]a^3[/itex]. By the quadratic equation,
[tex]a^3= \frac{n\pm\sqrt{n^2+ 4\left(\frac{m}{3}\right)^3}}{2}= \frac{n}{2}\pm\sqrt{\left(\frac{n}{2}\right)^2+ \left(\frac{m}{3}\right)^3}[/tex]
Since [itex]a^3- b^3= n[/itex], [itex]b^3= a^3- n= -\frac{n}{2}\pm\sqrt{\left(\frac{n}{2}\right)^2+ \left(\frac{m}{3}\right)^3}[/itex].
To use that formula on this equation, [itex]x^3- x^2+ x- 2= 0[/itex], first "reduce" it. Let [itex]y= x+ \alpha[/itex] so that [itex]x= y- \alpha[/itex], where [itex]\alpha[/itex] is yet to be determined.
[tex]x^3= y^3- \alpha y^2+ \alpha^2y- \alpha^3[/tex]
[tex]-x^2= -y^2+ 2\alpha y- \alpha^2[/tex]
[tex]+x = y- \alpha[/tex]
so that [itex]x^3- x^2+ x- 2= y^3- (\alpha+ 1)y^2+ (\alpha^2+ 2\alpha+ 1)y- (\alpha^3- \alpha^2+ \alpha+ 2)[/itex]
The coefficient of [itex]y^2[/itex], [itex]-(\alpha+ 1)[/itex] will be 0 if [itex]\alpha= -1[/itex].
And in that case, the coefficient of x, [itex]\alpha^2+ 2\alpha+1= 1- 2+ 1i= 0[/itex] also, and the constant term, [itex]-(\alpha^2+ \alpha+ 2)= -(1- 1+ 2)= -2[/itex]. That is, the equation is equivalent to [itex]y^3- 2= 0[/itex] or [itex]y^3= 2[/itex] so that we don't really need the cubic formula. The roots are the three complex cube roots of 2: [itex]2^{1/3}[/itex], [itex]2^{1/3}(-1/2+ \sqrt{3}i/2)[/itex], and [itex]2^{1/3}(-1/2- \sqrt{3}i/2)[/itex].
Since [itex]x= y- \alpha[/itex] and [itex]\alpha= -1[/itex], the roots to the original equation are [itex]2^{1/3}+ 1[/itex], [itex]2^{1/3}(1/2+ \sqrt{3}i/2)[/itex], and [itex]2^{1/3}(1/2- \sqrt{3}i/2)[/itex].
There exist a similarly complicated formula for fourth roots but it can be shown that there cannot be a general formula, using roots (there can be formulas with specially defined functions) or polynomial equations of degree five or higher.
You have to be careful when you pick random polynomials of degree higher than 2. You can easily give yourself a very hard problem.
Here's the solution, as computed by Wolfram Alpha:[PLAIN]http://www3.wolframalpha.com/Calculate/MSP/MSP127319h9270497i48ggd000068ih6e0d8gg59b01?MSPStoreType=image/gif&s=31&w=500&h=62
Not exactly something I would want to work out by hand...
This is an advanced Algebra problem requiring knowledge of the Factor & Remainder Theorems, Division Algorithm, Zero Factor Property
Some choices to proceed ....
1/ Cardano has a formula for 3rd degree polynomials which is similar but more complex than the Quadratic Formula for 2nd degree polynomials
2/ Newton's Method can find the first root quickly. Then long division to get the remaining quadratic.
3/ Trial and Error to find the first root often works.
4/ Rational Root Theorem
So draw a graph. Or get out a graphing calculator. It's not that hard.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 23 ·
