How to Solve Improper Integral: Tips & Tricks
The discussion revolves around techniques for solving an improper integral of the form \(\int_{-\infty}^{\infty}e^{-(ax^2+b/x^2)}dx\). Participants explore various methods, including differentiation under the integral sign, and share insights from related literature.
  • Homework-related
  • One participant seeks assistance in solving the integral and mentions using various techniques without success.
  • Another participant asks about the context in which the integral was encountered.
  • A participant clarifies that the integral was found in a paper discussing the probability of Brownian motion crossing a specific line.
  • Several steps for solving the integral are proposed, including differentiating under the integral sign and making a change of variable.
  • Another participant expresses gratitude for the provided steps and links to additional resources related to the topic.
  • Links to relevant papers are shared, which discuss the application of the integral in probability calculations.
Participants generally agree on the methods to approach the integral, but there is no consensus on the effectiveness of the techniques or the final solution, as the discussion remains exploratory.
Some steps in the proposed solutions depend on assumptions about the behavior of the integral under certain conditions, and the discussion does not resolve the mathematical intricacies involved.
techmologist
How do you get this:
[tex]\int_{-\infty}^{\infty}e^{-(ax^2+b/x^2)}dx = \sqrt{\frac{\pi}{a}}e^{-2\sqrt{ab}}[/tex]
I've been trying all the tricks I know, like differentiating under the integral sign and whatnot, but I can't get it. Thanks.
In which course did you run into this monster?
Not in any course. I came across it in a paper where they calculate the probability that a Brownian motion X(t) crosses the line at+b at some point during the interval (0, T).
Send a link of the paper?
1)Let I be your integral
2)Find I' by differentiating under the integral sign with respect to sqrt(b)
3)Effect the change of variable u=sqrt(b/a)/x (break up the interval at 0)
4)Notice I=-2sqrt(a)I'
5)Conclude I=I0 exp(-2sqrt(ab))
6)Compute I0
sqrt() denotes the square root
I' is the derivative of I with respect to sqrt(b)
I0 is your integral when b=0
See this thread
Feynman's Calculus
6)Compute I0
See this thread
Feynman's Calculus
Thanks, lurflurf! That's exactly what I needed. Well done. That's an excellent thread you linked to, also. Surely, You're Joking is where I first learned about differentiating under the integral sign. I apparently need more practice at applying it, though.
Sure. Here is the paper where the probability is calculated (near the end) using Laplace transforms:
http://projecteuclid.org/DPubS?service=UI&version=1.0&verb=Display&handle=euclid.pjm/1102911625
Here is a paper that makes use of the result. Scroll down to where it says "Kelly Criterion"--that's it. In the section on probability of reaching a goal within a certain time.
http://edwardothorp.com/id10.html
  • · Replies 27 ·
  • · Replies 19 ·
