How to stabilize voltage on a mV scale using a DC power source?
To stabilize voltage on a millivolt scale for calibrating a thermometer, a precision voltage source is ideal but can be costly. Constructing a solution using a DC power source is feasible by incorporating components like resistors and zener diodes, though these may not provide the best stability. A recommended approach is to use a voltage reference PMIC that outputs a stable voltage, followed by an instrumentation amplifier to scale it down to the desired 39.000 mV. This method ensures accuracy and reduces noise, temperature effects, and offsets. Seeking detailed tips from experienced individuals in electronics can enhance the construction process.
creetski
Hello,
I'm in the process of calibrating a thermometer/datalogger (Omega DP470) that uses a thermocouple type T (-200-350 deg. C range), and I need a DC voltage source that can feed a steady voltage of 39.000 mV. I believe at this point I can either purchase a precision voltage source that can feed a steady voltage on a millivolt (mV) scale, or manipulate/construct my own using my (0-20V) DC source.
The problem is that precision voltage sources are fairly pricey for such a task (~$1000.00), and I would rather construct something that can stabilize my voltage. I am able to dial down the knob on my current DC source to around 39.000 mV; however, it is obviously going to be noisy. Several people suggested putting some resistors in series and see if that would do it, while others have mentioned using zener diodes to maintain a steady voltage. I'm a little on the inexperienced side when it comes to EE and am curious if anyone out there has dealt with a similar situation? Any help or (detailed) tips are highly appreciated!
Thank you.
Get yourself a voltage reference PMIC (Power management IC). Let's say that you pick on that outputs 5V like this one from Texas Instruments. Follow that with an instrumentation amplifier which scales the 5V down to 39mV. Then you'll have an accurate 39mV with good immunity to noise, temperature, and offsets.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
