If you get both positive and negative values for the function from various choices of the variables, the function is neither positive (i.e. nowhere negative) nor negative (i.e. nowhere positive). There are regions where it is positive, and regions where it is negative. Since plugging in points only can only demonstrate whether a fuction is neither positive nor negative, here's one way you can see if the function is positive or negative:
Look for discontinuities in the function, and zeros of the function. If there are none, test a point, and the sign of the function at that point will be the sign of the function everywhere. If there are discontinuities or zeros, they will form the boundary between regions. Test each of the regions, and if each test point has the same sign, that is the sign of the function.
Something else you can do is take the absolute value of the function. If |f| = f over the entire domain, then f is positive. If |f| = -f over the entire domain, then f is negative. Otherwise, it's neither.
