I How well can we 'see' at different wavelengths?
  • I
  • Thread starter Thread starter physea
    Wavelengths
Various methods exist for 'seeing' different materials, including light, infrared, laser, ultrasound, and magnetic fields, each with unique advantages and limitations. A comprehensive table detailing the pros and cons of these methods, their resolution capabilities, and the materials they can detect is sought. The relationship between wavelength and the size of objects that can be resolved is crucial, particularly in optical methods like near-field microscopy, which can achieve nanometer resolution. However, techniques like magnetic force microscopy operate without wavelength considerations, directly sensing magnetic interactions. Understanding these distinctions is essential for selecting the appropriate method for specific applications.
physea
Hello! There are various methods to 'see' things. Light, infrared, laser, ultrasound, magnetic field, etc.
Is there a comprehensive table that will list the pros and cons, limitations and advantages, how distinctive each method can be (ie can distinguish 1mm or 1nm?), what materials they can see etc?
Thanks!
Look up the relationship between the wavelength of the "light" and the size of the object that can be resolved by that light.
Likes davenn
Regarding the title change, I am not sure if wavelengths are always involved, eg in magnetic field?
This does not work if you include modern scanning probe methods in microscopy; specifically near-field microscopy which makes it possible to even use microwaves to study surfaces with nm resolution. The spatial resolution is (mainly) only limited by the size of the tip used to scatter the light.
Near-field methods like SNOM, NSMM etc are quite widely used these days .
Note also that these methods are really optical; your signal is really the collected light; meaning they are distinct from say atomic force microscopy(AFM) or scanning tunneling microscopy (STM)
Likes CWatters
Magnetic force microscopy (MFM) which is essentially one (of many) version of atomic force microscopy senses the force from the magnetic interaction between sample and tip directly. Hence, there is no wavelength involved.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
