How will the pitch of a string change when I stretch it? (sound)
The discussion centers on calculating the change in frequency of a string when stretched by a specific amount (0.14 mm). Participants emphasize the importance of understanding the relationship between tension, length, and mass per unit length, noting that stretching alters both the length and mass per unit length of the string. Key insights include the necessity of measuring initial frequency and fractional change in length to estimate new frequency without needing to know the string's mass or modulus. The conversation highlights the requirement for specialized instruments to accurately measure tension and perform tensile strength tests on the string.
  • Understanding of wave velocity and fundamental frequency in strings
  • Knowledge of tension and its effect on string properties
  • Familiarity with mass per unit length calculations
  • Basic principles of string instruments and their mechanics
  • Research the relationship between tension and frequency in vibrating strings
  • Learn about tensile strength testing methods for strings
  • Explore the effects of string aging on frequency and tension
  • Investigate the use of specialized instruments for measuring string properties
Musicians, guitar builders, and acoustics researchers interested in understanding the physics of string instruments and optimizing their performance through precise measurements and calculations.
  • #31
  • #32
JT Smith said:
I thought you wanted to know how much the frequency changed when you stretched the string by 0.14mm? If what you really want to do is recognize notes there is likely already software that will do that.
There have been apps that can transfer the notes from an instrument to Midi code for years. I haven't understood how the (now revealed) requirement of the OP wouldn't be met by this.
I don't know the error rate of this sort of conversion software but 'proof listening' would be pretty easy.
  • #33
Thank you. I basically don't need as much as I thought I would. I was unsure whether I could distinguish vibratos and notes. I don't have a pickup around to test, and we are being locked down. So I figured I would work on a hardware a little.
I would rather adjust individual frets then bridge. If I adjust the bridge, I don't have guaranteed known cross section of fret board. The elliptical theory suggests that open string has no tension, which is not true. There is a given ratio of tension open string vs. plucked string. This ratio can be measured and each fret can be moved towards the nut by the ratio times length of vibrating section of the string.
The downsides are that it will only work for particular set of strings.
However I don't necessarily need any of these. I can just choose intervals of notes as needed. Say I have 5 instances of F#4 on my fret board, each a bit different. If I play a vibrato around any of these ranges, it will count as F# with vibrato for the MCU. Is that correct?
My vibratos are subtle. I play three distinct types depending on my mood, but none of them moves the string up and down as in common rock guitar vibrato. The distinction in terms of frequency change may not be too easy.
I take my time to think through resonant frequency idea. I thought I would use whatever the highest frequency MCU can output. I should be big enough a capacitor to shift that frequency reliably when in contact.
  • #34
Maybe the discrepancies of my old fret board could be used to my advantage. From frequency alone the guitar could distinguish a position where the melody is being played, no? And output a tabelature.
  • #35
I need quick release fretboards.
  • #36
Do you not have an electric guitar available? That's seriously all you need for the biggest part of your project (as you have stated it).
You seem to want to get in much deeper than necessary for a perfectly good experiment.
Tension from the machine head is the same as tension due to pressing with your fingers (at least, when using steel strings). It is easy to calculate string tension by applying a measured load (hanging a mass from a horizontal string) and measuring the displacement. You don't need to hang masses from a string hanging over a pulley. (Which is what the pictures of school experiments always show)
The standard of construction of even a modest instrument would be hard for anyone but an accomplished woodworker. Laying out a fretboard well is best done on a proper jig. Any special construction would only le necessary way down the line.
  • #37
I agree this is overkill. But I've been wanting to build my own guitar ever since before I bought one, and now that I can I want to make it count. I think I will manage to avoid the tone modification after all, with just a fretboard. On a scale 1 (very easy) and 10 (very difficult) the calculation I am going through is more than 1, that's for sure. I always think it is done and fix the last bug only to discover three more bugs. I am enjoying myself.
I want the guitar to be smart, to understand music, but preferably acoustic.
  • #38
JT Smith said:
I just read one guy's opinion that the strings become uneven over time and that messes up intonation. He didn't explain why though.
Well, the frets on my guitars definitely show wear. It seems reasonable that strings suffer as well.
  • #39
They get corroded over time - even when not being played - but sweaty fingers spoil them. 'Good' players wipe down and lubricate strings after playing. Instrumentalists have a whole stock of well founded and unfounded opinions about how to improve. There's no end to it.
That's an accurate description of the whole of life. :smile: I think you have to accept that you will need to set yourself intermediate goals and feel your way through this. Are you saying that you do not actually own a guitar with any sort of pickup?
  • #41
Sure, strings wear, visibly even. What I meant by "He didn't explain why" is precisely how the wear translates into a change in intonation. Why would uneven wear cause the string be flat at the twelfth fret?
  • #42
Does anybody understand what the OP is asking? I thought I knew at first but now must admit I have no clue. Is he building a guitar now?
  • #43
Good question. When testing intonation one is comparing vibration of the full string to half the string under slightly more tension. The part vibrating when fretted is the half I'd expect to be the least worn. Could be the change in tension between un-fretted and fretted effectively decreases because the cross section of the string is eroded?
  • #44
Maybe. If I'm doing the calculation correctly you'd need to lose about 1mg (about 0.1 cubic millimeter) from a .010 steel string to make it go flat by a few cents. One could test this with careful cutting and a good scale. I wonder though if defects are more to blame than actual change in mass or diameter. I notice my plain strings feel a little "wavy" when they get older, almost as if they are slightly bent where they contact the frets.
  • #45
The wear I'm thinking of is at each fret location. It would be like cutting small flexures at every fret. This would have the effect of reducing the average spring constant for the string.
Another thing to consider is work hardening. I just don't know which way that would trend.
  • #46
I am done. I don't think it was really worth it. Check out the results before and after factoring in the third step (strings pressed vs open. "pred" means before and "po" after). The results are in mm. These are last few lines:
Code:
pred  [1.4404296789560043, 93.62769589051987, 0.24132288857279646]
po  [1.440429678909144, 93.62769588747395, 0.24132288857104095]
pred  [1.6666666594460722, 108.33306298894432, 0.27922557999291575]
po  [1.6666666593975659, 108.3330629857914, 0.2792255799908845]
pred  [1.8359374919842715, 119.33563969474247, 0.3075844279608739]
po  [1.8359374919345335, 119.3356396915095, 0.3075844279586363]
pred  [1.9966125401166401, 129.77949180603417, 0.3345031781814851]
po  [1.996612540065733, 129.7794918027252, 0.3345031781790516]
pred  [2.18749999250063, 142.18714530153696, 0.3664835740720298]
po  [2.187499992448334, 142.18714529813775, 0.36648357406936366]
pred  [2.330322257526184, 151.47056940169833, 0.39041135204829086]
po  [2.330322257472849, 151.47056939823153, 0.39041135204545063]
pred  [2.4999999930012002, 162.49959473250186, 0.4188383706173862]
po  [2.4999999929466306, 162.49959472895483, 0.41883837061433915]
If you can confirm this it would be great.
  • #47
Why do you think that a reduced spring constant for the upper half of the string would cause the lower part to go flat?
  • #48
because the tension is determined by the full string not just the lower half. Lower tension lower pitch.
  • #49
I am catching the last minutes of a weekend, I've got much work next week. Here is what I have so far. First picture shows ellipse, if you look closely. Upper spikes of teeth count. Second picture is 3d view. True temperament frets, elliptical fretboard, fanned scalloped neck.
  • #50
I don't get it. If you lower the tension won't the string be out of tune?
  • #51
I'm having a hard time with the magnitude of the fret corrections you're calculating. They seem disproportionately large and discontinuous fret to fret.
  • #52
We're talking about the change in pitch added by the tension incurred by pressing the string to the 12'th fret. Initially the bridge is adjusted such that the twelfth harmonic matches in pitch with the pitch obtained when the string is pressed into the 12'th fret. The strings age and wear. The wear reduces the string material at each fret as time passes. The stiffness at these wear points is reduced. Now the string looks like many springs of slightly differing stiffness connected in series.
Years pass (I recall 20 years or so if I read the OP correctly)
The guitar is then tuned before testing. The open string now vibrates at the nominal pitch. The harmonic is sounded. Works great because the wavelength is exactly halved the open string value. Now the string is depressed. Since the stiffness has been reduced at the wear points, the tension increase by pressing into the fret is now less than it was initially when the guitar intonation was set. This causes the note to be flat.
  • #53
Thanks, that makes sense. But I don't think it works. When you fret a string (gently) you form a kind of triangle between nut, fret, and bridge. The string elongates by only a tiny amount, assuming the action isn't crazy. For a twelfth fret action of 2mm you'd expect the frequency at the twelfth fret to increase by less than 1hz. So it would be impossible to lose a few cents. If the action were higher, say 5mm, the stiffness would have to decrease by about 25% to flatten by that much, which seems kind of unlikely. I think you'd notice that when winding the string.
So unless the action is quite high, or maybe with non-metal strings, it doesn't seem to me that a loss of stiffness explains it.
  • #54
kokes said:
I was trying to search but found no results.
Is there a way to calculate how frequency will change if I stretch a string by certain amount (0.14 mm in my case)?[
Yes.
I found out I can measure its frequency once stretched, but no results as of how to estimate new frequency ahead of the time. I know a speed of string can be calculated from its weight, length and tension, but that doesn't seem to get me anywhere:
Use the formula for the frequency of a string under tension. Several things to consider. As you stretch the string, the mass density will decrease slightly. Is this important for your purpose? If so, look up Poisson's ratio.
You can find a wealth of string data at the D'Addario website to compare your results with. They have data for all of their strings giving pitches at different tensions based on a 25.5 in scale length. Beware of the formulae they use. They've written things in a way that combines factors to give weird dimensionless constants so that people who aren't physicists won't go, "WTF?" and get confused. Instead, physicists will look at it and go "WTF?" Their formulae are correct, but the "magic numbers" like 386.4 might not be obvious. Do a google search for D'addario string data.[/quote]
  • #55
Paul Colby said:
The properties of strings change with time. I find it takes about a day for a new set to stop stretching. My guess is they lose stiffness as the age.
The metal work hardens, plust oxidation plus grime at random spots. My strings always feel really slinky before stretching them out and get a bit stiffer to bend to the same pitch. Supposedly, boiling them will somewhat restore them, which I assume is some sort of annealing, but it seems too low a temperature for that. I've personally never tried that, but that's the lore. Maybe it just removes the grime and oxidation well.
  • #56
There are different lengths to consider. One is the scale length, which is the distance from the nut to the bridge. The other is the total length of the string, since the tension in the entire string changes, so to figure out what are younge in tension you need, you have to consider the length of the string from the tuners to the tailpiece.
I hope you have the proper tools for this. If you are using a scalloped neck, the reason for scalloping is that you do not push the string to fretboard. If you try to set it up by pushing the string all the way to the fretboard, you will never get it in tune across the fretboard. With scalloping, the idea is to just press lightly enough for the string to make contact with the fret. You have to have a very light touch to play that in tune.
As far a temperment goes, if you aren't using equal temperment, playing in any but the key it's tempered for is a problem. That's the issue Bach settled with equal tempered tuning. Every key is a few cents out of tune, but you can play in any key. The fanned frets just give you different scale lengths for different strings, presumably to make the tension across the strings uniform. (This problem and others were solved by Ned Steinberger with calibrated double ball strings. BTW, Ned's father was a Nobel Prize winner in physics for discovering the muon neutrino.)
  • #57
It's not the increase in length he's discussing; it the change in string modulus, which is affected by both sections of the string. Your finger pressure may have a small effect on that because a metal clamp would isolate the two sections but your finger is not a Capo.
  • #58
There a few basics that you need to sort out. The 'ellipse' theory only predicts the incremental increase in length (= extension) and the tension is incremental too.
Also, you really need to understand the way that equations can be re-arranged and variables eliminated. This is the point I was making at the top of the thread. The best way to approach a problem is to make the experimentation as simple as possible. Only when the simple approach becomes untenable do you go deeper. At the moment, everything you seem to want i.e. detecting vibrato, as a frequency variation, and applying a suitable model to what's happening. That can be done with string length measurements and frequency - if you can come to terms with what the Maths is telling you. What sort of balance do you have that will tell you anything about mass per unit length to an appropriate accuracy? Frequency and incremental length measurements are potentially much easier and much more precise. Otoh, tension and linear density are harder.
  • #59
When you fret a string it elongates slightly and this results in an increase in tension and hence pitch. Paul Colby was suggesting that the average string constant of the string decreases with use and this results in less of an increase in pitch when the string is fretted.
What I'm saying is that because the elongation is so small the resultant increase in pitch is too small for this to make sense. The string constant would have to change by far more than is likely.
  • #60
It’s the tension change per unit length that is reduced. The length change due to fretting remains constant.
On my electric guitars the bridge position (string length adjustment) depends quite a bit on which string. I attribute this to the variation of the tension delta on fretting depending on wire gauge and string height. What’s your explanation?
  • · Replies 31 ·
  • · Replies 58 ·
  • · Replies 27 ·
