How would you match up these Z-transforms?
jami8337
In Figure Q1b (on the next page), two plots display samples of the continuous-time signal uct(t) = sin(2πt) and two plots display samples of the continuous-time signal vct(t) = e −t sin(2πt). For each signal, the samples in the corresponding plots are obtained with two different sampling times. Associate each of the four plots with the corresponding Z transform in the list and justify your answer:
Four Z-transform expressions numbered 1 to 4: (1) 0.06216z over z^2 - 1.9762z + 0.9802; (2) 0.12533z over z^2 + 1.9842z + 1; (3) 0.1874z over z^2 - 1.9646z + 1; (4) 0.07755z over z^2 + 1.2278z + 0.3829.
Four-panel figure of discrete-time sample plots (a) to (d), each with index k from 0 to 50 on the horizontal axis and values from -1 to 1 on the vertical axis; panel (a) shows a slowly varying hump, (b) and (c) show oscillating sinusoid-like samples, and (d) shows samples decaying quickly to zero.
Table of Z-Transforms
Ok so using considering the generic denominator of the Z transform of a sinusoid:
z2+2cdz+d2
I can see that both equations 2 and 3 have a value of d=1 hence they are both undamped systems, so they are either one of (b) or (c)
Then from the generic denominator equation:
for (2) c=-2cos(ωT) =1.9842
= cos(ωT) = -0.9921
For (3) c=-2cos(ωT) =-1.9646
= cos(ωT) = 0.9823
Its at this point I am stuck on what I need to do and how to see which one of b and c is the correct plot?
Thanks for any tips!
In (b) you can count the samples per periode ( about 33.2 samples ). As one period is 360°, (b) matches a polepair = 1 / ±10.84°.
Now solve the roots in denominator in 2) and 3). See if there is a match.
Sorry for the late response, my revision swapped to a different module. That's great thank you managed to solve it for the correct answer using that
