How would you minimise these gravimetric analysis errors?
  • Thread starter Thread starter man0005
    Analysis Errors
This discussion focuses on minimizing errors in gravimetric analysis, specifically when using Barium Sulfate (BaSO4) as a precipitate. Key issues identified include the presence of impurities that increase the weight of the precipitate and the low solubility of BaSO4, which can lead to incomplete dissolution during washing. The concept of coprecipitation is highlighted as a significant factor affecting the purity of the precipitate. Additionally, the methodology of sampling from different sections of a non-homogeneous fertilizer sample is proposed as a potential solution to achieve more accurate results.
  • Understanding of gravimetric analysis techniques
  • Knowledge of coprecipitation phenomena
  • Familiarity with Barium Sulfate (BaSO4) properties
  • Basic sampling methodologies in analytical chemistry
  • Research methods to reduce coprecipitation effects in gravimetric analysis
  • Learn about the solubility principles of Barium Sulfate (BaSO4)
  • Explore sampling techniques for heterogeneous materials in analytical chemistry
  • Investigate purification methods for precipitates in gravimetric analysis
Chemistry students, laboratory technicians, and researchers involved in analytical chemistry and gravimetric analysis, particularly those working with precipitates and sample purity issues.
man0005
-precipitate not being pure e.g. other ions (present in the precipitate increasing the weight of the precipitate)
- in an experiment where BaSO4 is used and some of it isn't dissolved in the wash due to the 'low solubility' of BaSO4 - resulting in a lower weight, decreasing the percentage by mass of the precipitate.
-impurities in the sample
Sometimes called coprecipitation.
No idea what you mean.
How is it different from the first point?
But, it is up to you to try to solve the question. So, how do you propose to minimize errors?
with the co precipitation
since I am finding the amount of sulfur in a samle of fertiliser
Since the sample is non homogenous, you could get samples from the bottom, top and middle of the fertiliser and test them? Then average them out?
Could you please help me elaborate on that/explain it a little better ><
Sorry, I have no idea what you are asking about.
Methodology of taking samples has nothing to do with coprecipitation.
22K
18K
