Can anyone explain why my HP laptop's battery suddenly discharges twice?
  • Thread starter Thread starter danthemanutd
    Battery Laptop
HP laptop battery issues can arise when the battery does not recharge despite being plugged into the mains, often showing 0% charge. Common troubleshooting steps include removing and reseating the battery to ensure proper contact. Potential causes for battery failure include overcharging or exposure to excessive heat, which may damage the battery's internal monitoring system. This system, found in most modern laptop batteries, regulates charge and discharge and may have a reset option. Users have reported concerns about battery discharge affecting laptop performance, particularly in gaming scenarios, indicating that battery health can impact overall system speed.
danthemanutd
HP laptop battery problem!
hi, does anyone know why my battery on my HP laptop doesn't recharge when it is plugged into the mains?? It says it is 0% and charging but never actually increases. If you unplug the AC adapter it doesn't turn itself off but keeps warning me that it is at 0% and should be plugged in.
The laptop is only about 5 months old so shouldn't really have this sort of problem.
Any ideas are welcome!
Oh, the model number is HP Pavillion dv4, if that helps??
Cheers for any feedback,
dan
Computer science news on Phys.org
Try removing the battery and re-seating it, it could just be a bad contact.
More likely is that you have killed the battery, by over charging or too much heat.
There is a tiny computer in most modern laptop batteries that also monitors the charge/discharge, there might be a reset button on the battery to clear it's memory.
There is a tiny computer in most modernhttp://www.etech.com/laptops-laptop-batteries--c1146_1162" that also monitors the charge/discharge, there might be a reset button on the battery to clear it's memory.
wow, I like you says,so the beauty of notebook PCs is the portability, making them an essential device with an obivous advantage of mobility over desktop computers. Of course, after several hours, you will need to recharge your laptop's battery, plugging an AC charger from the mains into your laptop, which means, for a short period of time, it's fixed to one place, making it effectively a desktop PC for a short while.
Try removing the battery and reinstalled, it was just a bad contact.
It 's more likely that you've killed the battery or extreme heat.
There is a small computer in most modern laptop batteries, which also controls the charge / discharge can eliminate a reset button on the battery for the memory.
my HP laptop's battery discharge twice, does it affects on my laptop speed or 3dcard?? b/coz looks like my game (battle-field-3) is bit slow after dat accident of discharging,,,as my laptop is HP 6series with 1gp 3dcard.Thanks for reply in advance.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
