Ht12e/d input output logic question
2 replies · 2K views
vavapg
Good day.
I'm currently in the soldering phase of an RF circuit designed to operate an L293D motor chip. On the breadboard I managed to get it to work, but after soldering (and checking for shorts) I am not getting proper high/low signals sent through the encoder/decoder from 2 2p2t switches to the motor driver chip. The only variable I can think of is that in soldering, I put the positive leads from the switches to the 9v rail instead of the 5v regulator chip like I did on the breadboard. The data sheet says this is still within operating range for the encoder. Would a difference in voltage sent to the encoder data pins effect the transmitter signal to the decoder and out to the motor chip? As far as I know, they just operate on logic high/low signal.
Thanks for any help.
Since your problem relates to an encoder/decoder and switch, part numbers on those are needed, along with a circuit schematic of both the intended wiring and what the possibly bad wiring was. Also what voltage levels do you get and what other devices are to those points? Without this information we are operating on zero information regarding what is desired and what is actually happening.
What do you get? Nothing? The Local radio station :-)
