Humans Move Before Becoming Black Hole
Ted Baas
The question kind of says it all. How fast fast could a human move before Relativistic mass made him collapse into a black hole(the answerer can choose whatever mass and volume that they want for the equations).
A search of these forums will turn up many copies of the answer: There is no such speed. No matter how fast you go, you do not become a black hole. Velocity is a frame-relative quantity. You cannot make someone turn into a black hole or not simply by choosing a different reference frame.
Likes Nosebgr and bcrowell
This is a misconception. You will not turn into a black hole because of relativistic mass. In your rest frame, absolutely nothing changes and you can always describe things using that frame. Relativistic mass is generally not a concept in use by professional physicists. See our FAQ in the Insights section.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
