Will Increased Distance Affect Hydraulic Elevator Performance?
  • Thread starter Thread starter trickyrick
    Hydraulics
Using a forklift as an elevator with a 5 hp motor and pump raises concerns about performance when increasing the distance between components. Moving the motor and pump 44 feet away may not significantly impact operation if the flow rate is around 2 to 2.5 GPM and the system has minimal elbows. However, using hydraulic hose for a permanent installation is discouraged due to potential aging issues and inferior flow characteristics compared to tube or pipe. Accurate flow rate measurements are crucial for assessing pressure drop and overall system efficiency. Proper installation choices will ultimately affect the hydraulic elevator's performance.
trickyrick
I have taken the front end of a fork lift and using it in my new house as an elevator. I am using a 5 hp 220v moter to turn a pump off a woodsplitter. This is within 4 feet of the forklift. I want to move the motor and pump away from the elevator there would now be 44 feet of 3/4 in hose between the two. My question is would the motor and pump have to work a lot harder to operate the elevator.
Thanks
Rick
So I'm guessing the flow is about 2 to 2.5 GPM and you won't use hose, but tube or pipe? Pressure is around 2500 psi, maybe a bit more? Number of elbows is small (say less than 10). Hydraulic oil is about the same as water? Given the above, the 44 feet isn't a problem. Pressure drop is about 1 psi for a .65" ID.
Thanks for the reply. What do you mean not to use hose. I was going to buy Hydraulic hose 3/4 in OD. There would be no elbows and the pressure gauge only goes as high as 1200 psi
Using hose for a permanent installation is a very poor way of going. They tend not to age well. Also, the ID of the hose is generally much less than a tube or pipe of the same OD. Overall, they don't have very good flow characteristics.
Do you know your flow rate? That makes all the difference in the world when calculating pressure drop.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
