How Do You Expand a Hydrogen Atom State in an Orthonormal Basis?
carlosbgois
[/B]
Consider a hydrogen atom which, in t = 0, is in the state given by
\psi(\mathbf{r},t>0)=\frac{A}{4\pi}R_{10}(r)+\frac{cos\alpha}{4\pi}\left(\frac{z-\sqrt{2}x}{r}\right)R_{21}(r)
Expand ψ in terms of the nlm} basis of normalized eigenfunctions
\phi_{nlm}(\mathbf{r})=R_{nl}(r)Y_l^m(\theta,\phi)
The result should be
A\phi_{100}(\mathbf{r})+\frac{cos\alpha}{\sqrt{3}}[\phi_{210}(\mathbf{r})+\phi_{211}(\mathbf{r})-\phi_{21,-1}(\mathbf{r})]
Apart from having the supposed solution, I have no idea where to start.
Any help is appreciated.
You are required to show any of your initial effort before others can help you.
Do you understand the general principle of writing a state as a linear combination of orthonormal basis states? And how, in general, to determine the coefficients?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
