Hydrostatic Test: Calculate Leakage Rate of Thread & Coupling
  • Thread starter Thread starter Northdust
    Hydrostatic Test
The discussion centers on conducting a hydrostatic test on two short pipe sections connected by a round thread coupling, aiming to pressurize the system to 6000 kPa for one hour to measure any pressure drop and determine the leakage rate. The setup includes measuring initial and final pressures, temperatures, and the volume of the test fluid, which is water. Suggestions for calculating leakage include using Boyle's Law for gas or collecting leakage volume directly, with a flow meter recommended for accurate measurement. If the seals hold, no flow will occur; if there is a leak, the flow meter will indicate the rate. Accurate calculations can also utilize the bulk modulus of water for further analysis.
Northdust
I am looking to conduct a hydrostatic test on two short pieces of pipe connected via coupling a round thread coupling. Our intent is to pressurize the sample to 6000 kPa and hold for 1 hour to see if there is any sort of pressure drop, and if so what is the leakage rate of the system through the thread and coupled connection.
With this set-up we will know (or approximately know) the volume of the sample, the density of the test fluid, both initial and final pressure, both initial and final temperature (hopefully constant), and time the sample was pressurized.
If there is a drop in pressure over this time frame could someone help me determine the quantity of the test fluid that has leaked from the test specimen.
Regards,
Northdust
If the fluid is a gas and can be treated as ideal, just use Boyle's Law with the total test duration to get the volumetric flow of the leak.
The test fluid will be water.
Collect the leakage or measure the volume injected to maintain pressure.
The true way to do it is to put a flow meter in line with the pressure producing part, i.e. pump. If the seals hold, there will be no flow. If there is a leak, the flow meter will tell you the rate. You can put a totalizer counter on the flow meter to give you the total amount flowed.
Regards,
Northdust
Use the bulk modulus of water:
http://hyperphysics.phy-astr.gsu.edu/HBASE/permot3.html
CS
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
