I don't know how to get equation 4.41 here in the image
  • Thread starter Thread starter Shuvro1994
Shuvro1994
I don't know how to get equation 4.41 here in the image.
Please see the image I shared and help me to get equation 4.41 from equation 4.39 and 4.40
That's a lengthy process. Note that A still appears, so only B,C,D have been eliminated using the four equations. One way to approach this:
Solve the first equation for B, use that in the second equation. Now B is gone. Solve the second equation for C, plug that into the remaining two. Now C is gone as well. Solve one of the last two equations for D, plug it into the other one, solve for E, simplify.
Probably a bit less messy: Solve the first equation for B, use that in the second equation. Write it as ##Ce^{ik_2a}=...## and use that in the other two equations. Solve one of them for ##De^{-ik_2a}=...##, plug it into the other one, and then solve for E.
Eq 4.40 is easy to solve for both C and D. Now use Eq 4.39 equation to eliminate B from 4.39(i) equation by putting into 4.39(ii) equation. Now simply put value of C and D in this equation and you will easily get value of E as advertised!
Cramer’s rule may help lessen the amount of algebra you need to do.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
