I dont understand how to find the work done
  • Thread starter Thread starter snash1057
    Work Work done
To find the work done by the brakes on a car, the driver needs to calculate the correct acceleration using the formula for distance and time. The initial attempt to find acceleration was incorrect, leading to mistakes in calculating force and work. After correcting the algebra, the driver successfully determined the right values, leading to the correct answer. Understanding the relationship between acceleration, force, and work is crucial in solving such physics problems. Accurate calculations are essential for determining the work done in stopping the vehicle.
snash1057
i don't understand how to find the "work" done
A driver of a 7475 N car passes a sign stating "Bridge Out 25 Meters Ahead." She slams on the brakes, coming to a stop in 10 s. How much work must be done by the brakes on the car if it is to stop just in time? Neglect the weight of the driver, and assume that the negative acceleration of the car caused by the braking is constant.W=Fdcos
i tried finding acceleration by doing 25=1/2a(10^2) = .125
then finding mass by doing 7475=m(9.8)= 762.76
and then Fnet = 762.76 x .125 = 95.35
w= 95.35(25) = 2383.63
___________________________________________________
i also tried finding Vf by using 25=1/2(0+Vf)10 = 1.25
then i tried finding kinetic energy by 1/2(7475)(1.25^2)= 5839.84but neither of them are right so i have to be doing something wrong
You had 25=1/2a(10^2) = .125 . ?I think you meant that a = .125, but that's wrong. Check your algebra.
is it .5 rather?
OH GOSH! i can't believe i made that dumb of a mistake! haha i got the right answer! thank you for correcting my algebra!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
