PaulRacer
- 44
What would a clock do at the center of the Earth compared to a clock on the surface and why?
DaleSpam said:It would run slower because there is a gravitational redshift.
No. Every part of this setup is stationary wrt each other.PaulRacer said:Thanks Dale. So if you drilled a hole to observe it, wouldn't that hole at some point become twisted sort of like a yoyo string?
It isn't. What is strongest at the surface is the force one feels. The gravitational potential (the strength of the field) is strongest at the center. The reason no force is felt at the center is that every particle in your body is being pulled in all directions at once.v2kkim said:Something is going strange in this dialog. I think the gravitation effect is stronger on the Earth surface and minimum at the center of the earth.
Redshift or time dilation?DaleSpam said:It would run slower because there is a gravitational redshift.
russ_watters said:Redshift or time dilation?
russ_watters said:No. Every part of this setup is stationary wrt each other.
PaulRacer said:How is that possible with the object spinning? If the spinning is calculated in distance/sec., and the seconds are longer in the center...? Let's say the center clock is slower by 1 second per x amount of years, then it should take the center x years times 86400 to be one rotation behind the surface right?
sylas said:No. As Russ says, every part is stationary with respect to every other part. They ALL spin and in a way that there's no twist introduced. As measured from anyone point, all parts spin at the same rate.
However, the rate of spin as measured from different locations is different.
The proper inference of your thought experiment is that the rate of spin in radians per second is greater when measured from the middle than when measured from the surface. But no matter where you make the measurement, that spin the same at all levels. There's no "twist", because the difference is from time dilation, not from any relative movement.
Cheers -- sylas
PaulRacer said:Okay, if what you are saying is true, then is it possible for it to be perceived as twisted but actually not be physically?
PaulRacer said:What about time dilation on the surface due to angular velocities within the spinning sphere? (I think I got my terminology right) Does the gravitational redshift make the entire object time neutral? Sorry, I meant to ask this first.
George Jones said:The only way to find out is to do some sort of a calculation. For example, a calculation might show that, as DaleSpam states, one effect dominates, or a calculation that includes both effects, as I have done (using a low level of mathematical rigor) in
https://www.physicsforums.com/showthread.php?p=1543402#post1543402.
I am not sure what you are referring to here. Do you mean a twisting due to gravity or a twisting due to the rotation? Any twisting will be due to the rotation rather than the gravity.PaulRacer said:What is the answer to the hole question? Is the Earth wound like a clockspring inside?
Austin0 said:Hi perhaps you can clear up a question I have regarding the difference [if any?] between redshift and time dilation in this situation.
As per Sylas's scenario: there is an EM source at the center . an electron (1) with a low resonant frequency.
At the surface that photon is absorbed by an electron with a lower frequency than an electron on the surface comparable to electron (1)
By comparison the photon is considered red shifted .
But this scenario could be explained two ways.
The electron frequencies at the center were dilated by location and the photon was emited at that frequency and was unchanged by the translation to the surface.
No redshift. Only Time dilation affecting the electrons.
The photon itself was lowered in frequency through transit ,up the well so to speak.
Redshift.
Both of the above.
I hope you can shed some light on this question.
Thanks
DaleSpam said:Gravitational redshift implies gravitational time dilation. Consider a transmitter that transmits a perfect 1 MHz sinusoidal wave. That is a clock. If the signal goes up a gravitational potential it may be received at .99 MHz due to gravitational redshift. Unlike in the normal Doppler case the time between transmission and reception is not changing, so there are no transmission delay effects to correct for wrt the frequency. This implies that the frequency of the transmitter is lower and its time must therefore be dilated.
atyy said:See Cliiford Will's comments on p49/50 of http://books.google.com/books?id=9ZuP9JQzc00C&dq=clifford+will+einstein&source=gbs_navlinks_s . Basically, the distinction is not a concept with an operational meaning.
Austin0 said:Hi thanks for the link, although I tried it and didnt get through.
I understand that it does not have an operational meaning. It is a phenomenon and practically speaking the reality behind it is not relevant to how we deal with it.
But conceptually I think it might have some relevance regarding understanding gravity and its interaction with photons.
Thanks for the input
I am not sure what you mean by this. Let's say that you have an array of identical receivers at different altitudes. A receiver at the same altitude of the transmitter would receive a 1 MHz signal and receiver at progressively higher altitudes would receive progressively lower frequencies. This is what is observed experimentally, but I don't know if this is what you are describing.Austin0 said:it would seem to mean the signal itself was initially emitted at .99MHz and did not change during transit.
atyy said:I meant that there is no conceptual relevance because a concept is defined by an experiment. The underlying concepts are (i) metric which defines null, timelike, spacelike geodesics (ii) atomic clocks tick proper time (iii) photons follow null geodesics.
Twisting due to rotation and time rate differences within a single object. How could you view a clock moving at a conflicting rate in the center and not have a "twist". Whether time dilation is caused by gravitational redshift or angular velocities doesn't really matter.DaleSpam said:I am not sure what you are referring to here. Do you mean a twisting due to gravity or a twisting due to the rotation? Any twisting will be due to the rotation rather than the gravity.
It sounds like you think there should be some twist, even in the case of a non-rotating planet, purely due to the gravitational time dilation. This is not correct, any twist is entirely due to the rotation of the planet and would occur even for a hollow (no significant mass) rotating planet.PaulRacer said:How could you view a clock moving at a conflicting rate in the center and not have a "twist".
DaleSpam said:It sounds like you think there should be some twist, even in the case of a non-rotating planet, purely due to the gravitational time dilation. This is not correct, any twist is entirely due to the rotation of the planet and would occur even for a hollow (no significant mass) rotating planet.
I certainly didn't say that. You would conclude that your speedometer was correct, and that the mile markers were spaced too closely (length contraction).PaulRacer said:Ok, so you are saying that if I was traveling in a car at .5c and I started counting off mile markers to calculate speed compared to my watch that I would conclude that the speedometer was wrong even though it is correct.
DaleSpam said:I am not sure what you mean by this. Let's say that you have an array of identical receivers at different altitudes. A receiver at the same altitude of the transmitter would receive a 1 MHz signal and receiver at progressively higher altitudes would receive progressively lower frequencies. This is what is observed experimentally, but I don't know if this is what you are describing.
DaleSpam said:That is not how it works. The person at the center of the Earth will measure the length of a day to be slightly less than the person at the surface of the earth.
DaleSpam said:I certainly didn't say that. You would conclude that your speedometer was correct, and that the mile markers were spaced too closely (length contraction).
This is a conceptual error. "In reality" the length of time (the number of seconds in a day) is not the same at the two locations.PaulRacer said:If the person at the center of the Earth measures the length of day to be slightly less when in reality the length of time that elapsed was the same
The person traveling in the car is a SR scenario and the person in the center of the Earth is a GR scenario. They are not equivalent. The SR effects exist in GR, but not vice versa.PaulRacer said:and their rotations were in sync with the person on the surface wouldn't the person traveling in the car be much like the person in the center of the earth?
